OSPF config to pair with OpenWRT
Hi all,
I’d like to connct routerOS with openwrt..
My network already have ospfd running and redistributing network routing tables.
I tried to pair it with mikrotik router without success.
What do I need to do to match this config:
! OSPFD configuration
hostname NODE4
password xxxxx
enable password xxxxx
no banner motd
router ospf
	network 192.168.11.0/24 area 1
ospf router-id 192.168.11.1
redistribute connected
! Enable RFC-1583 compatibility to avoid routing loops
    compatible rfc1583
line vty
!log file /var/log/quagga/ospfd.log
Thank you!
Assuming the router id for the other side is 192.168.11.2 , this should be all you need to match that config.
/routing ospf instance
set [ find default=yes ] router-id=192.168.11.2 redistribute-connected=as-type-1
/routing ospf network
add area=backbone network=192.168.11.0/24
