Hello
Attached is found a diagram of my network.
From each “Area” we have a network 172.16.x.0/24 (where area 2 has 2.0; area 3 has 3.0 etc)
All traffic, some from area 2 and some from area 3 will go out through FW (FW1 or FW2)
Actually everything works.
We have OSPF running between backbone and the towers.
The CORE AREA (area 1001 and 1002) has some problems.
From the tower I am not able to reach 10.0.1.1 or 10.0.2.1, the core routers, BTW.
All devices are MT with 5.22.
What do you think about this setup?
I will ask you some info about VRRP+OSPF that is giving me problems, but later!
I will attach some confs:
FW1:
/routing ospf area
add area-id=10.0.1.0 name=“Core RA”
/routing ospf instance
set [ find default=yes ] redistribute-connected=as-type-2 router-id=172.16.0.241
/routing ospf interface
add interface=“ether2 - Backbone Spadhausen” network-type=broadcast
add interface=“ether6 - Core RA” network-type=broadcast
/routing ospf network
add area=backbone network=172.16.0.0/23
add area=“Core RA” network=10.0.1.0/28
FW2:
/routing ospf area
add area-id=10.0.2.0 name=“Core Mezzano”
172.16.0.68
add interface=“ether5 - Backbone Spadhausen” network-type=broadcast
add interface=“ether2 - Core Mezzano” network-type=broadcast
add area=“Core Mezzano” network=10.0.2.0/28
