Hello everyone,
I have 2 wireless links with Ubiquiti Rocket Prism 5AC antennas between 2 nodes(router_1 and router_2). One link is called Ubiquiti_A and the other Ubiquiti_B. I’m using OSPF and path costs so that the downstream goes only over the Ubiquiti_A and the upstream over the Ubiquiti_B (from the WAN port perspective,being router 1 the one that provides the internet connection). Both links are NBMA network type due to problems experienced with others.
My question is: how is the correct way to configure the NBMA neighbors? Because when I use router 2 with Area Range to propagate summarized routes to router 1, both links start to share the load through downstream and upstream .Router 1 is DR in both links, is this wrong?
Here is my configuration:
Router_1(RB1100AHx4, ROSv6.49.2):
---Interface---:
/routing ospf interface add cost=10 interface="ether5_Ubiquiti_A" network-type=nbma priority=1
/routing ospf interface add cost=20 interface="ether6_Ubiquiti_B" network-type=nbma priority=1
---NBMA-Neighbor---:
/routing ospf nbma-neighbor add address=10.0.0.20 comment="Ubiquiti_A" priority=1
/routing ospf nbma-neighbor add address=10.0.0.52 comment="Ubiquiti_B" priority=1
Router_2(hEX S, ROSv6.49.2):
---Interface---:
/routing ospf interface add cost=20 interface="ether4_Ubiquiti_A" network-type=nbma priority=0
/routing ospf interface add cost=10 interface="ether5_Ubiquiti_B" network-type=nbma priority=0
/routing ospf nbma-neighbor add address=10.0.0.17 comment="Ubiquiti_A" priority=0
/routing ospf nbma-neighbor add address=10.0.0.49 comment="Ubiquiti_B" priority=0
All replies are appreciated.
