OSPF networks
why are the networks we add in OSPF shared to other routers?
configuration of the following instance:
/routing ospf instance> print
name="default"
router-id=10.255.255.2
distribute-default=never
redistribute-connected=no
redistribute-static=no
redistribute-rip=no
redistribute-bgp=no
redistribute-other-ospf=no
metric-default=1
metric-connected=20
metric-static=20
metric-rip=20
metric-bgp=auto
metric-other-ospf=auto
in-filter=ospf-in
out-filter=ospf-out
What is listed under OSPF Networks ?
[admin@R1] /routing ospf network> print
 #   NETWORK            AREA
 0   192.168.150.248/29 area1
 1   192.168.100.128/25 area1
[admin@R2] /routing ospf network> print
 #   NETWORK            AREA
 1   192.168.250.248/29 backbone
[admin@R1] /routing ospf route> print
 # DST-ADDRESS        STATE          COST          GATEWAY         INTERFACE
 0 192.168.100.128/25 intra-area     10            0.0.0.0         b-vlan100
 1 192.168.150.248/29 intra-area     10            0.0.0.0         b-vlan150
 2 192.168.250.248/29 inter-area     20            192.168.150.252 b-vlan150
[admin@R2] /routing ospf route> print
 0 192.168.100.128/25 intra-area     20            192.168.150.250 b-vlan150
 2 192.168.250.248/29 intra-area     10            0.0.0.0         b-vlan250
Why network 192.168.250.248/29 appear on the router1?
Why network 192.168.100.128/25 appear on the router2?
The purpose of OSPF is to exchange routes between routers, so OSPF is doing exactly what it was designed to do. :slight_smile:
R1 is learning 192.168.250.248/29 from R2 via OSPF
R2 is learning 192.168.100.128/25 from R1 via OSPF
Is this not what you wanted to happen?
So what are these settings for? Since they are in “no” were not supposed to not share?
When the subnet is added to ‘ospf network’ it will advertise the prefix
Ok, thanks!
If you would like 192.168.250.248/29 not to appear on router 1 you need move this network on router to into it’s own area so that it is not passed as a backbone area would be.
If you would like 192.168.100.128/25 not to appear on router 2 you should not put it in area1 as you defined area 1 on both routers.
What routes are you wanting to be passed between the two routers?
Thank you.
I’ve already tested what you said, and it worked. Thanks.
This doubt arose, since before they were allowed to share routes, they were already shared. However, it has already been explained that when I add a subnet to “OSPF networks” this will share its prefix.
good news.
