I have 2 routers, both running 5.9. This particular problem though, has been around since at least 4.11 or so. This problem is only happening between these two units and I’m unable to reproduce it anywhere else.
PTP, SR5, 38km, nv2, -54db, AP/Station modes.
When the station reboots (for any reason), the OSPF will not come up until I disable/enable the instance on the AP side.
The Station receives and installs routes from the AP, but the AP does not appear to be getting or installing routes from the Station. Both units recieve and install routes from all other neighbors (lan side).
Any ideas or suggestions on what to look at?
I did submit a ticket (2011120166000788) with before/after SUPOUT files for both units.
Thanks,
