I have couple routers in WiFi network with OSPF and MPLS because using VPLS tunnels. After upgrade one of them to version form v6 to v7.15 I can’t reach or ping other router using link address. If I change source address in trace tool to router id address or transport address then trace working.
If try to trace from 10.100.103.14 for example 10.100.103.21 it can’t but route exist in routing table.
Before upgrade that is working.
Anyone have idea what I am missing in v7 ? Why almost default OSPF+MPLS+VPLS not working after upgrade ?
Here is setting from that router with v7.
add address=10.50.103.1 interface=Bridge_loop network=10.50.103.1
add address=10.100.103.13/30 interface=wlan1 network=10.100.103.12
add address=10.100.103.17/29 interface=VLAN_Switch network=10.100.103.16
/routing ospf instance
add disabled=no name=default-v2 redistribute=connected router-id=10.50.103.1
/routing ospf interface-template
add area=backbone-v2 auth-id=1 auth-key="" cost=10 disabled=no interfaces=\
wlan1 networks=10.100.103.12/30 priority=1 type=ptmp-broadcast use-bfd=no
VLAN_Switch networks=10.100.103.16/29 priority=1 type=ptmp-broadcast \
use-bfd=no
/mpls ldp
add disabled=no lsr-id=10.50.103.1 transport-addresses=10.50.103.1
/mpls ldp advertise-filter
add advertise=yes disabled=no neighbor=0.0.0.0 prefix=10.50.0.0/16
add advertise=no disabled=no neighbor=0.0.0.0 prefix=0.0.0.0/0
/mpls ldp interface
add disabled=no interface=wlan1
add disabled=no interface=VLAN_Switch
