Ospf over wireguard flapping
Hello Everyone,
I need assistance on the below issue.
I have created OSPF on wireguard but its flapping
when i do continuous ping for the P2P on wireguard am getting time outs, when i disable OSPF, pings are stable.
What could be the problem?
Below are my configs for the hub site.
admin@R2] > export
2026-06-14 11:28:52 by RouterOS 7.12.1
software id = BD3D-PICM
model = CCR1036-8G-2S+
serial number = D83B0CCA9097
add admin-mac=48:8F:5A:F4:98:9D auto-mac=no comment=defconf name=bridgeLocal
add name=loopback0
/interface wireguard
add listen-port=13231 mtu=1380 name=wg0
/interface lte apn
add name=dhcp_pool0 ranges=192.168.88.2-192.168.88.254
/port
set 0 name=serial0
set 1 name=serial1
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing id
add disabled=no id=1.1.1.1 name=RID1 select-dynamic-id=""
add id=2.2.2.2 name=RID
/routing ospf instance
add disabled=no name=ospf-1 originate-default=never out-filter-select="" redistribute=connected router-id=2.2.2.2
/routing ospf area
add disabled=no instance=ospf-1 name=backbone
add bridge=bridgeLocal comment=defconf ingress-filtering=no interface=ether2
add bridge=bridgeLocal comment=defconf ingress-filtering=no interface=ether3
add bridge=bridgeLocal comment=defconf ingress-filtering=no interface=ether4
add bridge=bridgeLocal comment=defconf ingress-filtering=no interface=ether5
add bridge=bridgeLocal comment=defconf ingress-filtering=no interface=ether6
add bridge=bridgeLocal comment=defconf ingress-filtering=no interface=ether7
add bridge=bridgeLocal comment=defconf ingress-filtering=no interface=ether8
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=10.50.50.0/30,192.168.77.0/24,224.0.0.5/32,224.0.0.6/32 endpoint-port=13231 interface=wg0 persistent-keepalive=25s public-key="6DeH5Y0Cv3EdsydDKUbLrTz176B8FkWRe5p4Y/GTaz8="
add address=192.168.88.1/24 interface=bridgeLocal network=192.168.88.0
add address=10.255.255.2 interface=loopback0 network=10.255.255.2
add address=172.25.142.174/30 interface=sfp-sfpplus1 network=172.25.142.172
add address=41.216.66.178/30 interface=sfp-sfpplus2 network=41.216.66.176
add address=10.50.50.1/30 interface=wg0 network=10.50.50.0
add address-pool=*2 interface=bridgeLocal name=dhcp1
add address=192.168.88.0/24 gateway=192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
add action=accept chain=forward comment="Allow OSPF" protocol=ospf
add action=accept chain=input dst-port=51820 protocol=udp
add action=accept chain=input in-interface=wg0
add action=accept chain=input dst-port=13231 protocol=udp
add action=accept chain=input in-interface=wg0 protocol=icmp
add action=accept chain=forward connection-state=established,related
add action=accept chain=forward out-interface=sfp-sfpplus2 src-address=192.168.88.0/24
add action=drop chain=forward
add action=accept chain=input comment="Allow WireGuard" in-interface=wg0
add action=masquerade chain=srcnat out-interface=sfp-sfpplus2
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=41.216.66.177 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/lcd
set time-interval=hour
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/routing filter rule
add chain=ospf-out rule="if (dst == 0.0.0.0/0) { reject }"
add chain=ospf-out rule=accept
/routing ospf interface-template
add area=backbone disabled=no interfaces=sfp-sfpplus1 type=ptp
add area=backbone disabled=no interfaces=bridgeLocal passive
add area=backbone cost=10 disabled=no interfaces=wg0 type=ptp
/routing rule
add action=lookup comment="Protect WG" src-address=10.50.50.0/30 table=main
add action=lookup comment="Protect WG endpoint" dst-address=41.216.66.178/32 table=main
add action=lookup-only-in-table interface=sfp-sfpplus2 table=*400
add action=lookup table=main
/system clock
set time-zone-name=Africa/Lusaka
/system identity
set name=R2
/system note
set show-at-login=no
/system package update
set channel=development
Your firewall is concerningly minimalistic (suggest reverting to default one with the address lists and such and allowing necessary ports only) and there are some invalid entries here and there that may or may not be part of the problem. E.g.
/routing rule
