I have a routed network ospf. My Internet connection is in a CCR router with ospf and entered the network after a bridge is a RB1100 router ospf.
Currently I do not have any problems. But when I put the internes en SequreISP and is connected to the CCR, the no ospf AS Border Router publishes more with your gateway.
Someone can tell me where to look for the problem?
I do not fully understand your situation. You might try posting your question in your native language as well as English. I think something was lost in the translation.
Perhaps you could show us the configuration and the unexpected results?
My access point now, I have a CCR Administrator, where I do NAT, load balancing, QOS, etc. In this I have connected 3 CCR ADSL and leased line. My internal network is composed of 18 nodes with links, routers and redundant rings. All routing do work with OSPF. Everything works perfectly.
Now I incorporate SequreISP to manage users, bandwidth, qos, billing, help desk, etc.
The ADSL are connected to a RB260G, VLANS via the SequreISP, like dedicated line.
The problem is that the CCR is no longer publishing more on the net as SA, so that the entire network goes down.
The question is no longer publishes OSPF as gateway to CCR
adsl
adsl ---- switch vlan ---- sequreISP ---- CCR ---- ptp ---- RB1100 to other networks
adsl
Mi punto de acceso actualmente, lo tengo administrador con un CCR, donde hago NAT, Balanceo de Carga, QOS, etc. En este CCR tengo conectados 3 ADSL y una linea dedicada. Mi red interna esta compuesta por 18 nodos con enlaces, routers y anillos con redundancia. Todo el ruteo lo hago trabajar con OSPF. Todo funciona a la perfección.
Ahora incorporo SequreISP, para administrar usuarios, ancho de banda, qos, facturacion, mesa de ayuda, etc.
Los ADSL se conectan a un RB260G, por medio de VLANS al SequreISP, lo mismo que la linea dedicada.
El problema es que el CCR ya no se esta publicando más en la red como SA, por lo que toda la red deja de funcionar.
La pregunta es por que OSPF ya no publica al CCR como gateway
adsl
adsl ---- switch vlan ---- sequreISP ---- CCR ---- ptp ---- RB1100 a otras redes
adsl
RESOLVED
Good! Sorry I wasn’t able to be more helpful.
