OSPF Summarization not happening?
Hi All,
2026-10-07 13:50:19 by RouterOS 7.23.8
software id = xxxx-xxxx
model = RB960PGS
serial number = xxxxxxxxxxxx
custom default configuration script installed
see /system/default-configuration/custom-script/print
/routing ospf instance
add disabled=no name=default-v2 redistribute="" router-id=192.16.0.11
/routing ospf area
add disabled=no instance=default-v2 name=backbone-v2
add area-id=192.16.0.11 default-cost=1 disabled=no instance=default-v2 name=POPx no-summaries type=stub
/routing ospf area range
add area=POPx prefix=192.16.11.0/24
add area=POPx prefix=100.99.76.16/28
add area=POPx prefix=172.26.197.4/30
/routing ospf interface-template
add area=backbone-v2 auth-id=1 cost=10 disabled=no interfaces=eth01 networks=192.16.248.76/30 priority=1 type=ptp use-bfd=no
add area=backbone-v2 interfaces=Loopback networks=192.16.0.11/32 passive
add area=POPx disabled=no interfaces=all networks=192.16.11.0/24,100.64.0.0/10,172.16.0.0/12 passive
/ip/address/print
Flags: S - SLAVE
Columns: ADDRESS, NETWORK, INTERFACE, VRF
ADDRESS NETWORK INTERFACE VRF
0 192.16.248.78/30 192.16.248.76 eth01 main
1 192.16.0.11/32 192.16.0.11 Loopback main
2 S 192.16.11.30/27 192.16.11.0 VLAN-99_MGMT_wlan main
3 192.16.11.62/27 192.16.11.32 Bridge-VLAN-197_MGMT main
4 192.16.11.126/26 192.16.11.64 Bridge-VLAN-99_MGMT main
5 192.16.11.190/26 192.16.11.128 Bridge-VLAN-99_MGMT main
6 192.16.11.254/26 192.16.11.192 Bridge-VLAN-99_MGMT main
7 198.18.240.11/24 198.18.240.0 eth01 main
Can someone perhaps give me some hints here?
The LSA being advertised is:
S D instance=default-v2 area=backbone-v2 type="inter-area-prefix" originator=192.16.0.11 id=192.16.11.0 netmask=255.255.255.224 metric=1
I am however expecting the /24 to be advertised as configured in the area range? Not quite sure why it isn't....
Statics, and re-distributing statics, is unfortunately not an option. It will add MASSIVE complexities to our network. The route must be an inter-area summary
Thanks,
Guess it's something that's been fixed in stable, and not fixed in LTS releases.... Works on the latest versions.
[admin@hostX] > /routing/ospf/export
2026-11-11 17:55:40 by RouterOS 7.25.1
software id = IFLC-C1G8
model = RB960PGS
add disabled=no name=default-v2 redistribute="" router-id=192.168.0.11 version=2 vrf=main
/routing ospf area
add area-id=0.0.0.0 disabled=no instance=default-v2 name=backbone-v2 type=default
add area-id=192.168.0.11 default-cost=1 disabled=no instance=default-v2 name=hostX-v2 type=stub
add area=hostX-v2 prefix=192.168.11.0/24
add area=hostX-v2 prefix=100.99.76.16/28
add area=hostX-v2 prefix=172.26.197.4/30
add area=backbone-v2 auth-id=1 cost=10 disabled=no interfaces=eth01 networks=192.168.248.76/30 priority=1 type=ptp use-bfd=no
add area=backbone-v2 disabled=no interfaces=Loopback networks=192.168.0.11/32 passive
add area=hostX-v2 disabled=no interfaces=all networks=192.168.11.0/24,100.64.0.0/10,172.16.0.0/12 passive
[admin@hostX] > /ip/address/export
2026-11-11 17:55:44 by RouterOS 7.25.1
model = RB960PGS
add address=192.168.248.78/30 interface=eth01 network=192.168.248.76
add address=192.168.0.11 interface=Loopback network=192.168.0.11
add address=192.168.11.30/27 interface=VLAN-99_MGMT_wlan network=192.168.11.0
add address=192.168.11.62/27 interface=Bridge-VLAN-197_MGMT network=192.168.11.32
add address=192.168.11.126/26 interface=Bridge-VLAN-99_MGMT network=192.168.11.64
add address=192.168.11.190/26 interface=Bridge-VLAN-99_MGMT network=192.168.11.128
add address=192.168.11.254/26 interface=Bridge-VLAN-99_MGMT network=192.168.11.192
add address=198.18.240.11/24 interface=eth01 network=198.18.240.0
[admin@hostX] > /routing/ospf/lsa/print where originator=192.168.0.11
Flags: S - SELF-ORIGINATED; D - DYNAMIC
1 SD instance=default-v2 area=backbone-v2 type="inter-area-prefix" originator=192.168.0.11 id=192.168.11.0 sequence=0x8000000F age=404 checksum=0x7F84 body=
netmask=255.255.255.0
metric=1
[admin@hostX] >
