i’m new to OSPF. I’m trying to connect 3 Routers over WG( more later). I’m simulating this scenario on eve. I’ve setup the wireguard peers succesfully.
I’ve enabled the OSPF and have established connections with neighbours. R1 is the wireguard server. Topology:
i have different wg interfaces and ports for each peer. all in the same subnet 90.90.12.0/24
i have added 224.0.0.0/24 in the WG peers.
i have communication between R1-R2 and R1-R3 with the current configs but not between R2-R3. Any input would be appreciated.
R1 Configuration
add arp=proxy-arp name=Loopback
add arp=proxy-arp name=bridgeLAN
/interface wireguard
add listen-port=13231 mtu=1420 name=wg2
add listen-port=13233 mtu=1420 name=wg3
add disabled=yes listen-port=13235 mtu=1420 name=wg5
add name=dhcp_pool0 ranges=192.168.10.2-192.168.10.254
add address-pool=dhcp_pool0 interface=bridgeLAN name=dhcp1
/port
set 0 name=serial0
/routing id
add disabled=no id=9.9.9.1 name=9.9.9.1 select-dynamic-id=""
/routing ospf instance
add disabled=no name=ospf-instance-1 originate-default=always router-id=9.9.9.1
/routing ospf area
add disabled=no instance=ospf-instance-1 name=ospf-area-1
add bridge=bridgeLAN interface=ether2
add bridge=bridgeLAN interface=ether3
add bridge=bridgeLAN interface=ether4
/interface wireguard peers
add allowed-address=90.90.12.102/32,192.168.20.0/24,224.0.0.0/24 comment="to R2" endpoint-address=\
192.168.40.130 endpoint-port=13231 interface=wg2 persistent-keepalive=25s public-key=\
"oLLt0FWruEEAFp5PPmp8KiU+EkHfPGkaI4nZMaplPDs="
add allowed-address=90.90.12.103/32,192.168.30.0/24,224.0.0.0/24 comment="to R3" endpoint-address=\
192.168.40.131 endpoint-port=13233 interface=wg3 persistent-keepalive=25s public-key=\
"bv0L8Km40xd4FpOkKLpVRsa95GMIbJ1zKqH1IqusWiQ="
add allowed-address=90.90.12.105/32,192.168.50.0/24,224.0.0.0/24 comment="to R5" disabled=yes \
endpoint-address=192.168.40.133 endpoint-port=13235 interface=wg5 persistent-keepalive=25s public-key=\
"FlW3QsOYA0h9QLcU5RsmL60Nd+LiSegSlcJ+gHwVoCw="
add address=192.168.10.1/24 interface=bridgeLAN network=192.168.10.0
add address=90.90.12.2/24 interface=wg2 network=90.90.12.0
add address=90.90.12.3/24 interface=wg3 network=90.90.12.0
add address=9.9.9.1 interface=Loopback network=9.9.9.1
add address=90.90.12.5/24 interface=wg5 network=90.90.12.0
/ip dhcp-client
add interface=ether1
add address=192.168.10.0/24 gateway=192.168.10.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/routing ospf interface-template
add area=ospf-area-1 auth-key="" disabled=no interfaces=wg2,wg3 type=ptmp-broadcast
add area=ospf-area-1 disabled=no interfaces=bridgeLAN type=ptp
/system identity
set name=R1
R2 Configuration
add listen-port=13231 mtu=1420 name=wgR2
add name=dhcp_pool0 ranges=192.168.20.2-192.168.20.254
/port
set 0 name=serial0
/routing id
add disabled=no id=9.9.9.2 name=9.9.9.2 select-dynamic-id=""
add disabled=no name=ospf-instance-1 originate-default=always router-id=9.9.9.2
/routing ospf area
add allowed-address=90.90.12.2/32,192.168.10.0/24,224.0.0.0/24 comment="to R1" \
endpoint-address=192.168.40.129 endpoint-port=13231 interface=wgR2 \
"F0wVnvFHBfwaQfmWphkZQeBYthX7cCh4AsuG0IOde1M="
add address=192.168.20.1/24 interface=bridgeLAN network=192.168.20.0
add address=90.90.12.102/24 interface=wgR2 network=90.90.12.0
add address=9.9.9.2 interface=Loopback network=9.9.9.2
/ip dhcp-client
add address=192.168.20.0/24 gateway=192.168.20.1
add area=ospf-area-1 disabled=no interfaces=wgR2 type=ptmp-broadcast
/system identity
set name=R2
R3 is the same with R2 on with 192.168.30.0/24 subnet.
