Hi I need help to develop scripts.
I want to take some values pinging.
for example I have this line in a script
Global pingresultA [/ ping 208.67.220.220 interface = ether6_WAN1 count = 5] \
And take a value if you are receiving ping or not. Now what I want for the new script is to take the values of MS “avg-rtt”
Pinging in mikrotik throws for example these results
SEQ SIZE TTL TIME HOST STATUS
0 56 56 8.8.8.8 62ms
1 56 56 8.8.8.8 300ms
2 56 56 8.8.8.8 237ms
3 56 56 8.8.8.8 63ms
4 56 56 8.8.8.8 62ms
sent = 5 = 5 received packet-loss = 0% min-rtt = 62ms RTT = 144ms avg-max-rtt = 300ms
As I get the script takes the value of avg-rtt.
Thank you very much
Deantwo
2
Using the ping command like that in the terminal only returns the number of successful pings.
For example this:
[admin@MikroTik] > :global test [:ping 8.8.8.8 count=5]
SEQ HOST SIZE TTL TIME STATUS
0 8.8.8.8 56 47 16ms
1 8.8.8.8 56 47 15ms
2 8.8.8.8 56 47 15ms
3 8.8.8.8 56 47 15ms
4 8.8.8.8 56 47 15ms
sent=5 received=5 packet-loss=0% min-rtt=15ms avg-rtt=15ms max-rtt=16ms
[admin@MikroTik] > :put $test
5
[admin@MikroTik] >
If what you want is a speed test, I suggest you look into the bandwidth test feature.
See: http://wiki.mikrotik.com/wiki/Manual:Tools/Bandwidth_Test
Thank you for answering, but what I want is to get the average response time (avg-rtt)
Deantwo
4
I don’t know if there is a way to get that.
But I know that it at least isn’t possible with the “:ping” command, as I demosatred above.
mrz
5
As stated previously it is not possible. You can get only count of successful replies.
