Hi, I would like to replace my old RB600 with tons of CM9s running on 5G A. Thinking what would be best solution. Can you please give me some ideas? 180° and CPE max 1km. is fine so I am thinking …
2 x sector antena mANTBox 120°
2 x sector antena mANT + NetBox 5 .. seems like similar RB inside so not sure it there is any different - maybe better all in one - option 1.
2 x other vendor sector 2xMIMO antena + NetBox 5 / NetMetal 5
2 x other vendor sector 3xMIMO antena + NetMetal 5 triple (i guess no need when most CPE has max 2 chains ants)
Is there any different running on 5G AC or N in the city? N better or not much differents (running 20 or max 40MHz anyway).
I prefer NetMetal 2x2, is more flexible. You can add different kinds of antennas. MIMO 2x2 is very popular and you have a diversity of antennas. mANT 120º is too specific design. NetBox is the same, but plastic (I prefer metalic case). NetMetal 3x3 if you not need it, choose 2x2.
