outgoing smtp
Hi
mikrotik ccr1016-12g
can’t access to external smtp servers.
After two month of properly work and upgrade to 6.31.2 I have no more aceess to external smtp servers (outgoing 25 port)
Who can help me, where to send “supout.rif” file?
Have you done a packet capture?
At support@mikrotik.com
Have you confirmed if port 25 is not blocked by your ISP?
Thanks to All
Yes it is right. An ISP blocked the port on 15 minutes if outgoing connections more than their limit. )))
Good to hear
Dont forget to give karma
What will you buy for karma? Isn’t the good feeling that you helped to someone enough for you?
It is not so hard, I gave you some karma. ))))
It gets me 1 reputation which is better than 0 " It cost noting to give" so why being bothered about me asking
