Is there a more up-to-date documentation about which router supports hardware acceleration? I would appreciate
information about ovpn (and other vpn), not just ipsec.
I was looking at https://help.mikrotik.com/docs/display/ROS/IPsec#IPsec-Hardwareacceleration
I tested a hAp ax2 (ARM64 IPQ-6010 cpu) and a Chateau LTE6 (ARM IPQ-6019 cpu) with ros 7.15.3, encryption aes256-cbc, configured vpn connection between these two routers.
IPSEC was hardware accelerated but in case of ovpn only the Chateau LTE6 used hardware acceleration. I would like some more accurate information before I decide which router to use instead of the 20+ RB951 model routers.
Anyway, I tested copying a a larger file through the vpn, from one windows machine to another and I was surprised by the results:
- fully hw-encrypted ipsec produced 20 megabyte/sec copy speed, hAp ax2 cpu load 16%, Chateau LTE6 cpu load 38%
- ovpn with only Chateau LTE6 using hw encrytpion produced 9 megabyte/sec, hAp ax2 cpu load 21% Chateau LTE6 cpu load 40%
That’s right, the hw encrypted side had much higher cpu load - no idea why, and cpu load did not depend on hardware encryption.
