OVPN:require client certificate not working anymore [SOLVED]
I’ve updated from v6.10 to v6.11 and the OVPN option “require client certificate” doesn’t work anymore!
If I remove the option I can login again with OpenVPN client on iPhone.
But with this option set I can’t login (in 6.10 it worked).
Can anyone confirm it?
Best regards
Carsten
Is client certificate from the same CA chain?
Confirming, after updating to 6,11 i have the same problem.
I have exactly the same problem
Downgrade to 6.10
Same problem here… :frowning:
yes.. problems is it.
Hello mrz,
yes, I only have one CA installed, and the client certificate is signed by this CA.
Downgraded to 6.10 and it works again.
I have seen that there was an issue with the client certificate option (that I did not have)
because the changelog of 6.11 says:
*) ovpn - fixed require-client-certificate
Regards
Carsten
Same problem for me.
I have CA and intermediate CA with LT status in ROS.
i can also confirm that since v6.11 “require-client-certificate” option does not work anymore!
Will be fixed in next version. It is related to CRL.
When is planned the next version ?
Hi folks,
today I upgraded to version 6.12 and openvpn didn’t work.
The flags of the CA and the router certificate after updating was only a big “T”
After I deleted the certificates (CA and signed certificate for router) and imported them again everythings works as expected. <== (I didn’t do this step in 6.11, maybe it works also here???)
The flags are: for CA = “AT” and for the router cert = “KT”
So, the option “Require Client Certificate” in version 6.12 works.
Best regards
