Package Combiner
I’ve made package combiner tool. Allows to create one combined package from custom packages. It doesn’t change packages context it simply merges them into one :slight_smile: Use it at your own risk!
Go there: http://ayufan.eu/local/combiner
Kamil
you need to download the all-packages on some directory? how the script get the packages?, you have some readme to implement it.
M.
http://ayufan.eu/local/combiner/download there is a script I use to download releases. Script is run from local package directory :slight_smile:
Integrations with other systems are prohibited. Script should be only available from my server!
