Passing a parameter from a script to another script
Hello everybody! This is not GPT! My question is: I want to pass a parameter from one script to another. What’s easier, you say, do it through global variables. But I want to do without variables (the interest is purely academic)
I managed to do it using this method:
script Transfer:
:local scrName "scriptReceiver"
:local Var1 "Par1=mytext"
:local Var2 "Par2=12"
:execute script="[[:parse \"[:parse [/system script get $scrName source]] $Var1 $Var2\"]]"
script Receiver:
:log warning "$Par1 $Par2"
:log warning [:typeof $Par1]
:log warning [:typeof $Par2]
:local Par3 [:tonum $Par2]
:log error $Par3
:log error [:typeof $Par3]
In the design :execute script=“[[:parse "[:parse [/system script get $scrName source]] $Var1 $Var2"]]”
:execute is clearly redundant, it is enough [[:parse "[:parse [/system script get $scrName source]] $Var1 $Var2"]]
From my experience, it can be seen that
  1. all parameters are passed as string parameters and after catching them, the receiver script must convert their type back, knowing it in advance.
  2. And secondly, strings can only be transmitted in Latin. I was unable to pass string parameters in the national language (say Cyrillic).
Questions:
  1. Is there any way to do this more gracefully? (without global variables and functions).
  2. And is it possible to somehow pass parameters with their types (not only in string form) and pass the Cyrillic alphabet? I tried to transfer Cyrillic alphabet in HEX format like \D0\E1, etc… - it doesn’t work.
Rex and Amm0 where are you friends?
Here, Russian friends gave me the idea that I was bothering a lot and that I could pass positional parameters like $0, $1, etc. from the script to the script … with the same construction. We should try it too.
and catching them in script Receiver is just like :local Par1 $0
Да, можно передавать и именованные и позиционные, но всё равно все превращаются в тип “str”
Yes, you can pass both named and positional ones, but still everything turns into the “str” type:
scrTransfer:
:local Var1 "12"
:local Var2 "Par2=13"
:local Var3 14
:execute script="[[:parse \"[:parse [/system script get $scrName source]] $Var1 $Var2 $Var3\"]]"
scr Receiver:
:log info $0
:log info [:typeof $0]
:log info $1
:log info [:typeof $1]
:log info $Par2
It turns out that you can pass parameters from a script to a script while preserving their type. This is done like this:
# Script transfer
:local Var1 "Par1=text"
:local Var3 14
:local Var4 192.168.0.1
:local Var5 [/system clock get time]
:log info ("$Var1"." $[:typeof $Var1]")
:log info ("$Var2"." $[:typeof $Var2]")
:log info ("$Var3"." $[:typeof $Var3]")
:log info ("$Var4"." $[:typeof $Var4]")
:log info ("$Var5"." $[:typeof $Var5]")
[[:parse "[:parse [/system script get $scrName source]] $Var1 $Var2 $Var3 [:to$[:typeof $Var4] $Var4] [:totime $Var5]"]]
# Script Receiver
:log warning ("$Par1"." $[:typeof $Par1]")
:log warning ("$Par2"." $[:typeof $Par2]")
:local Par3 $0
:local Par4 $1
:local Par5 $2
:log error ("$Par3"." $[:typeof $Par3]")
:log error ("$Par4"." $[:typeof $Par4]")
:log error ("$Par5"." $[:typeof $Par5]")
Place both scripts in your repository, run the first one and see what happens in the log
In my example, the parameters $Var1, $Var2 and $Var3 “lose” their type when they are all converted to type “str”, while the parameters $Var4 and $Var5 retain their type when passed
Pay attention to the line
and in it the entry [:totime $Var5]. To pass $Var5 as a “time” type, you need to explicitly specify this again for :parse, although $Var5 is already of the “time” type.
and the design for :parse
substitutes the type of the Var4 variable on the fly into the collected string.
I have no interest in complicating life unnecessarily.
If there is a quicker way, I don’t see why waste time with all these mental wanks…
I didn’t expect this from you. It always seemed to me that you love mental exercises. Regarding my question, do you have any ideas or solutions?
So far I have come to this final working design:
[[:parse “[:parse [/system script get $scrName source]] Par1=[:to$[:typeof $Var1] $Var1] [:to$[:typeof $Var2] $Var2] [:to$[:typeof $Var3] $Var3] [:to$[:typeof $Var4] $Var4] [:to$[:typeof $VarN] $VarN]”]]
Now I can pass parameters without losing their types. But I can’t pass the Cyrillic alphabet in string parameters. Do you have any ideas about this? I have not tried to transfer arrays.
Thank you, friends. I guessed it myself. It’s just that string parameters need additional escaping like “" hello мамочка!"” and then they are transmitted without problems !
If I’m getting it right, you are trying to build a code in which you insert the parameters as local variables and their
value as literals. There are lots of things that can go wrong there. And is not exactly parameter passing.
Let’s have the test script:
/log info "argByName:$argByName";
/log info "arg 0:$0";
/log info "arg 1:$1";
and the runtest script:
# get the script source
:local s [/system script get test source]
# make a local function from it:
:local c [:parse $s]
# run it supplying the arguments
$c argByName="Arg1" 1
For “purely academic” interest, have a look at this posting: http://forum.mikrotik.com/t/a-few-undocumented-operators-that-are-kind-of-neat/163557/1 especially the <%% operator.
It solves the problem with “overkill”, passing arguments by reference!
My mistake… . Having a closer look I realized that it is basically the same just your solution is a one liner.
I also had trouble with parameters turning into string. It seems putting the parameter in brackets will help:
[admin@DHCP-DNS] > :global f do={:put "$1 $[:typeof $1]"}
[admin@DHCP-DNS] > $f 2
2 str
[admin@DHCP-DNS] > $f (2)
2 num
[admin@DHCP-DNS] > $f 192.168.1.1
192.168.1.1 str
[admin@DHCP-DNS] > $f (192.168.1.1)
192.168.1.1 ip
