Hello All,
As this is my first time using this forum I am not too sure where to begin but I am I desperately need some help from anyone that can offer it.
I am currently using an RB450 for PPtP and Radius authentication for several remote RB433 base stations. When any user attempts to connect to the internet via the remote base station slash page they are unable to get a return url from PayPal and instead receive “page timeout” responses. I checked and rechecked the configuration of the RB450 and realized that the problem is with https/ port 443. The walled gardens are all fine because they all worked prior to this issue and Authorized.net is still working perfectly but PayPal and 2Checkout is not.
I was wondering if I can receive some assistance in fixing this problem. Below is a copy of my current configuration from the RB450, thank you in advance for ANY assistance that can be offered:
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=
10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s
udp-stream-timeout=3m udp-timeout=10s
add action=dst-nat chain=dstnat comment=“dst nat srv01 ssh” disabled=no dst-address=xx.xx.xx.xx
dst-port=22 protocol=tcp to-addresses=192.168.1.165 to-ports=22
add action=dst-nat chain=dstnat comment=“dst nat srv01 https” disabled=no dst-address=xx.xx.xx.xx
dst-port=444 protocol=tcp to-addresses=192.168.1.165 to-ports=444
add action=dst-nat chain=dstnat comment=“dst nat srv01 http” disabled=no dst-address=xx.xx.xx.xx
dst-port=80 protocol=tcp to-addresses=192.168.1.165 to-ports=8888
add action=masquerade chain=srcnat comment=“masquerade servers” disabled=no src-address=
192.168.1.0/24
add action=masquerade chain=srcnat comment=“masquerade managers” disabled=no src-address=10.3.3.0/24
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
Many Regards,
KC
