PBR base on destination ip address-list
I googled “routeros policy based on address-list routing”, get very little help. and I try to figure it out myself. I don’t know my configure is right or not, anyway post here.
set [ find default-name=ether1 ] name=ether1-ISP-1
set [ find default-name=ether2 ] name=ether2-ISP-2
add name=WAN-ports
add interface=ether1-ISP-1 list=WAN-ports
add interface=ether2-ISP-2 list=WAN-ports
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=124.127.1.2/30 interface=ether1-ISP-1 network=124.127.1.0
add address=114.240.2.2/30 interface=ether2-ISP-2 network=114.240.2.0
/ip firewall address-list
add address=1.2.4.0/24 list=list_ISP-2
add address=8.129.0.0/16 list=list_ISP-2
add address=14.204.0.0/15 list=list_ISP-2
/ip firewall mangle
add action=accept chain=prerouting comment="Accept traffic from WAN-ports" \
    in-interface-list=WAN-ports
add action=mark-connection chain=prerouting comment="from ISP-2 mark connection" \
    connection-mark=no-mark in-interface=ether2-ISP-2 new-connection-mark=ISP-2-in-connection \
    passthrough=yes
add action=mark-routing chain=output comment="ISP-2 reply PBRouting mark" connection-mark=\
    ISP-2-in-connection new-routing-mark=ISP-2-PBR passthrough=yes
add action=mark-packet chain=prerouting comment="base dst-ip-list ISP-2-PBR mark packets" \
    dst-address-list=list_ISP-2 in-interface=bridge new-packet-mark=ISP-2-PBR-packet \
    connection-mark=no-mark passthrough=yes
add action=mark-routing chain=prerouting comment="ISP-2 routing mark by packet" \
    disabled=yes new-routing-mark=ISP-2-PBR packet-mark=ISP-2-PBR-packet passthrough=yes
/routing table
add disabled=no fib name=ISP-2-PBR
/routing rule
add action=lookup-only-in-table disabled=no routing-mark=ISP-2-PBR table=ISP-2-PBR
add action=lookup disabled=no routing-mark=main table=main
add check-gateway=arp disabled=no distance=1 dst-address=0.0.0.0/0 gateway=124.127.1.1 \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=arp disabled=no distance=2 dst-address=0.0.0.0/0 gateway=114.240.2.1 \
add check-gateway=arp disabled=no distance=1 dst-address=0.0.0.0/0 gateway=114.240.2.1 \
    pref-src="" routing-table=ISP-2-PBR scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=arp disabled=no distance=2 dst-address=0.0.0.0/0 gateway=124.127.1.1 \
Use address-list because there are very long list of ISP-2, about hundreds CIDR, and that list will renew sometime. I’ve no idea how to renew this list in /routing/rule/.
I don’t mark ISP-1, because I also configured OSPF in this router, I need main routing table do its job, and its only needs 4 mangle works.
But in this way, I try to force router itself traffic base on address-list, not working. :frowning:
And sorry about my English.
add another mangle, it seems can base address-list, force router itself traffic, without traffic coming from internet.
/ip firewall mangle
add action=mark-routing chain=output comment="router itself base on address-list mark routing to ISP-2" \
    connection-mark=no-mark dst-address-list=List_ISP-2 new-routing-mark=ISP-2-PBR \
    out-interface-list=WAN-ports packet-mark=no-mark passthrough=yes src-address-type=local
works for now. :laughing:
No, that not working, cause packet loss in traffic send to ISP-2, I’m still working on it.
Is there somebody help me?
ok, this time, I test my configure for 2 hours, I think it works fine.
add action=masquerade chain=srcnat comment="NAT44 for WAN1" out-interface=ether1-ISP-1
add action=masquerade chain=srcnat comment="NAT44 for WAN2" out-interface=ether2-ISP-2
add action=dst-nat chain=dstnat comment="OpenVPN TAP server" dst-port=1194 in-interface-list=
WAN-ports protocol=tcp to-addresses=192.168.88.10 to-ports=1194
add action=dst-nat chain=dstnat comment="iperf server" dst-port=5201 in-interface-list=WAN-ports
protocol=tcp to-addresses=192.168.88.10 to-ports=5201
/ip firewall mangle
PBR interface needs config "Accept", if not, it will drop packet.
in my example, there is a port mapping set in LAN, a debian server direct link to bridge port.
But when I config accept everything, OVPN tun server in my router lost one client,
firewall cannot mark all connections. traffic from that client always no-mark.
add action=accept chain=prerouting comment="Accept dst-nat traffic from ISP-2" connection-mark=
no-mark connection-state=new dst-port=1194,5201 in-interface=ether2-ISP-2 protocol=tcp
add action=accept chain=prerouting comment="Accept masquerade traffic from ISP-2"
connection-nat-state=srcnat in-interface=ether2-ISP-2
mark connection in when traffic arrived PBR interface, thank anav,
RouterOS v7.0.5 Dual PPPoE Wan Setup. - #23 by anav
that is very great idea, traffic only in/out router and traffic forward from/to LAN needs 2 different marks,
I was use one at first, make traffic loop.
passthrough=yes
mark traffic from LAN and router itself
add action=mark-connection chain=output comment=
"base on dst-ip address-list ISP-2-PBR-connection mark -- router itself" connection-mark=
no-mark dst-address-list=List_ISP-2 new-connection-mark=ISP-2-in-connection
"base on dst-ip address-list ISP-2-PBR-connection mark traffic from LAN" connection-mark=no-mark
connection-nat-state=!dstnat dst-address-list=List_ISP-2 in-interface-list=LAN
new-connection-mark=ISP-2-PBR-connection passthrough=yes
/routing table
/routing rule
I wrote some note in configure, thank anav again.
I’m updated my configuration in nearly days, post it here. if anyone find my words is not English, please help my translate, thanks. :laughing:
My example is 2 of ISP line access to internet with two pairs IP addresses, a debian server dircetly link to lan bridge port, router runs several services, like a OVPN TUN server, a PPTP server, and the debian server runs another OVPN service in TAP mode use TCP, and iperf3 service.
I use address-list, not routing rule, because I need clients traffic who have a source IP in ISP-1 access services, but destination address is ISP-2 port, gets reply from ISP-2 port. Both WAN ports accept clients from internet, and masquerade traffic from LAN.
  1. Set ethernet interface name, I think it’s more clearly than comment:
In my example, set 3 ports to bridge, as LAN:
and I’m set up a list of interface for NAT.
add name=WAN-ports
  1. set IP address for each interfaces.
add address=192.168.88.1/24 comment=LAN interface=bridge network=192.168.88.0
  1. set address-list, in my example, I’m set up IPv4, this list actually in my router is very long, about hundreds CIDR, I pick 3 of them shows here.
also you can set a IPv6 address-list, but mangle should set in /ipv6/firewall.
/ipv6 firewall address-list
add address=2408:8000::/20 list=list_ISP-2
  1. set NAT, skip masquerade part if you are setting up in IPv6.
add action=masquerade chain=srcnat out-interface=ether1-ISP-1
add action=masquerade chain=srcnat out-interface=ether2-ISP-2
add action=dst-nat chain=dstnat comment="OpenVPN TAP server" dst-port=11194 in-interface-list=\
add action=dst-nat chain=dstnat comment="iperf3 server" dst-port=15201 in-interface-list=WAN-ports \
5.set mangle of firewall, the ether1-ISP-1 use main routing table, it’s no need set accept and mark connection, and my suggestion is only “Accept” the traffic forward from/to LAN, don’t set up for input/output traffic. reason is in my reply early.
/ip firewall mangle
add action=accept chain=prerouting comment="Accept dst-nat traffic from ISP-2" \
    connection-nat-state=dstnat in-interface=ether2-ISP-2
add action=accept chain=prerouting comment="Accept masquerade reply traffic from ISP-2" \
and mark connection when traffic arrive, here I changed configure, different from early post. Input/Output and Forward traffic needs two mark like before. but if you’re set up a dst-NAT, mapping port for a service outside your local LAN, PREROUTING seems not work. “connection-nat-state=!dstnat” not work well in FORWARD chain, my idea is use dst-port make router match traffic, this value should be original port in your local LAN, NOT mapping outside you config nat in WAN ports.
/ip firewall mangle
add action=mark-connection chain=input comment="input ISP-2 port traffic mark connection" \
    connection-mark=no-mark connection-nat-state=!srcnat,dstnat connection-state=new \
    dst-address-type=local in-interface=ether2-ISP-2 new-connection-mark=\
    ISP-2-in-out-connection passthrough=yes
add action=mark-connection chain=forward comment="from ISP-2 port dst-nat traffic mark connection" \
    connection-mark=no-mark dst-port=1194,5201 in-interface=ether2-ISP-2 \
    new-connection-mark=ISP-2-PBR-connection passthrough=yes protocol=tcp
and base on destination ip address-list, or PCC, what ever you want, mark connection forward from LAN to ISP-2. dst-nat in traffic and forward from lan traffic can use same connection mark name.
/ip firewall mangle
add action=mark-connection chain=prerouting comment=\
    "from local subnet base on dst-ip address-list ISP-2-PBR-connection mark" connection-mark=\
    no-mark connection-nat-state=!dstnat dst-address-list=List_ISP-2 dst-address-type=\
    !local in-interface=brideg new-connection-mark=ISP-2-PBR-connection passthrough=yes
if you want use PCC, only set up PCC=2/1 is alright, 2/0 should go to main connection mark, and main routing table. don’t use “src-address and port” in the situation which is two of your ISP line are rent from different provider, it’s will cause safety failure for bank web site, and some SSL problem you are not expecting.
/ip firewall mangle
    "from local subnet base on PCC ISP-2-PBR-connection mark" connection-mark=\
    no-mark connection-nat-state=!dstnat dst-address-type=!local in-interface=bridge \
    new-connection-mark=ISP-2-PBR-connection passthrough=yes \
    per-connection-classifier=src-address:2/1
if you want base on source vlan or source IP address, just change condition make router find your traffic.
/ip firewall mangle
    "from local subnet base on src-ip traffic ISP-2-PBR-connection mark" connection-mark=\
    no-mark connection-nat-state=!dstnat in-interface=vlan2 dst-address-type=\
and you can set up router itself output traffic base destination ip address-list use ISP-2 port, if you like.
add action=mark-connection chain=output comment=\
    "router itself base on dst-ip address-list ISP-2-PBR-connection mark" connection-nat-state=\
    !dstnat connection-state=new dst-address-list=List_ISP-2 new-connection-mark=\
    ISP-2-in-out-connection passthrough=yes src-address-type=local
mark routing.
add action=mark-routing chain=output comment="ISP-2 In/Out mark routing" connection-mark=\
add action=mark-routing chain=prerouting comment="ISP-2-forwarding mark routing" \
    connection-mark=ISP-2-PBR-connection new-routing-mark=ISP-2-PBR passthrough=yes
  1. Set up routing table and routing rule, about ISP-1, it’s use main table, should in configure already.
/routing table
/routing rule
  1. Set up static route, don’t forget main route table need access to internet.
I hope everything is fine this time. :slight_smile:
