this does not helps me my frind
the main aim from loadbalancing is to get 2 lines work with each others !!
so my second line does not work with PCC i dont know why i neeeeeeeeeeeeeeeed help plz !!
Like heislerb said, with PCC any single connection will have max 4Mbit.
The PCC rules you created will devide traffic based on source and destination IP + Port.
So if you are downloading something from Microsoft, your IP + MS’s IP will be calculated and the connection will be routed over 1 of the 2 lines.
The principle of PCC is that all the bandwidth available (4 + 4) will be shared by all the clients together, but any given connection will only be possibly as fast as the fastest single connection.
It is hard to create a setup where the speeds are combined for 1 single connection.
In that case you need a device on each end of the lines which will bound the two individual lines together.
But I assume that the other side of the line is you ISP so you won’t be able to place any device on that other side.
aha okay i understand what u said but i c 2 many Tutorials on youtube.com and arabic fourms when they make PCC they get the max speed for each lines both !!
look at this arabic tutorial
[youtube]https://www.youtube.com/watch?v=15LngWiDZaU[/youtube]
this for person his name shady and he is an expert in mikrotik networks and he talk about combined 8 lines with 21 mega speed and he used internet download manger to show us how he get download traffic from all lines
but he used PCC method with bridge and he link all routers with each others and used 2 ports from mikrotik port for internet out and the other for internet in !!
so … ??
You said it for youself. Download manager (eg jdownloader) uses many connections to same file and thats why it uses all lines. If he just download a file from web browser it will use just one line. Try it yourself. Use a download manager and see both lines working!
i want the same config... but !!!!!
i have to login via pppoe clients for my two lines...
i taste it with this config but dindt work.. because of the pppoe client and not a static ip from isp..
some things have to change and i taste a little bit but it works not !
what must i do to run PCC with load balancing with two ADSL pppoe lines ???
please help...
ip address
