PCC load balance, but pc got 2 default gateway !help
i have 2 WAN network, and 1 out LAN
on pc i use auto dhcp, but always got 1 default gateway form WAN, any way to isolate??
where am i setting wrong or any missing? TQ
add admin-mac=2C:C8:1B:23:2E:69 auto-mac=no fast-forward=no name=bridge
set [ find default-name=ether1 ] arp=local-proxy-arp comment=\
    "Backup Netinstall" name=1Master
set [ find default-name=ether2 ] arp=local-proxy-arp comment="WAN port" name=\
    2WAN
set [ find default-name=ether3 ] arp=local-proxy-arp name=3WAN
set [ find default-name=ether4 ] name=4LAN
set [ find default-name=ether5 ] name=5LAN
add name=LAN
add name=WAN
add name=pool_DHCP ranges=192.168.3.1-192.168.3.250
add address-pool=pool_DHCP disabled=no interface=bridge lease-time=5h10m name=\
    server1
add bridge=bridge interface=4LAN
add bridge=bridge interface=5LAN
/interface bridge settings
set use-ip-firewall=yes
/ip settings
set tcp-syncookies=yes
add interface=bridge list=LAN
add interface=2WAN list=WAN
add interface=3WAN list=WAN
add interface=4LAN list=LAN
add interface=5LAN list=LAN
add interface=1Master list=LAN
add address=192.168.2.1/23 interface=bridge network=192.168.2.0
/ip dhcp-client
add add-default-route=no disabled=no interface=2WAN use-peer-dns=no
add add-default-route=no disabled=no interface=3WAN use-peer-dns=no
add address=192.168.2.0/23 dns-server=192.168.2.1 gateway=192.168.2.1
set allow-remote-requests=yes servers=208.67.222.123,208.67.220.123
/ip firewall address-list
add address=www.facebook.com list=Blacklist
add address=shopee.com.my list=Blacklist
add address=lazada.com.my list=Blacklist
add address=taobao.com list=Blacklist
add address=www.lazada.com.my list=Blacklist
add address=192.168.2.0/23 list=Local_network
add action=drop chain=forward port=80,443 protocol=tcp src-address-list=\
    Blacklist
add action=drop chain=input connection-state=invalid
/ip firewall mangle
add action=accept chain=prerouting dst-address=192.168.0.0/24 in-interface=\
    bridge
add action=accept chain=prerouting dst-address=192.168.100.0/24 in-interface=\
    bridge
add action=mark-connection chain=prerouting connection-mark=no-mark \
    dst-address-type=!local in-interface=bridge new-connection-mark=WAN1_conn \
    passthrough=yes per-connection-classifier=both-addresses-and-ports:2/0
    dst-address-type=!local in-interface=bridge new-connection-mark=WAN2_conn \
    passthrough=yes per-connection-classifier=both-addresses-and-ports:2/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
    in-interface=bridge new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
    in-interface=bridge new-routing-mark=to_WAN2
add action=mark-routing chain=output connection-mark=WAN1_conn \
add action=mark-routing chain=output connection-mark=WAN2_conn \
add action=masquerade chain=srcnat out-interface=2WAN
add action=masquerade chain=srcnat out-interface=3WAN
/ip firewall service-port
set sip disabled=yes
add check-gateway=ping distance=1 gateway=192.168.0.1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=192.168.100.1 routing-mark=to_WAN2
add check-gateway=ping distance=2 gateway=192.168.100.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=n0
Observations.
  1. MISSING firewall rules to protect your router and LAN network.
    Suggest put in default rules.
(2) remove this setting (select NO) and use the normal
/ip firewall rules for input chain and forward chain.
(3) Your mangle rules… add the modifications and the missing lines.
/ip firewall mangle
add action=accept chain=prerouting dst-address=192.168.0.0/24 in-interface=bridge
add action=accept chain=prerouting dst-address=192.168.100.0/24 in-interface=bridge
in-interface=bridge new-routing-mark=to_WAN1 passthrough=yes
in-interface=bridge new-routing-mark=to_WAN2 passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no
in-interface=ether2 new-connection-mark=WAN1_conn passthrough=yes
in-interface=ether3 new-connection-mark=WAN2_conn passthrough=yes
  1. It looks like you have fixed private IPs as your internet connections, thus why do you not have an IP address setting for both WANs??
    Okay, whoever is feeding you that connection may prefer dynamic?? and thus the use of dhcp client?
#whoever is feeding you that connection may prefer dynamic
yes, is using dhcp client connect
I don’t see any way how router could cause this. Don’t you just have 192.168.0.1 as another manual gateway in Windows config?
Adapter properties → IPv4 → Advanced → Default gateways
i just Auto obtain IP address, not manual input ip
I understand, but even with dhcp enabled, it’s still possible to have another forgotten manually configured gateway in advanced setting, from some past experiments perhaps. Did you check that it’s really not there?
