Hello Guys,
I recently acquired a new Hap Ax^3 (C53UiG+5HPaxD2HPaxD) router. By this occasion I tried to set it up PCC LB+FO config, but the settings for one of my ISPs is quite strange (further referred as O2). In this case, the connection is ADSL2: the phone lines are connected to a bridge and the bridge to my router where I have to set a VLAN and PPPoE. How this setup works, I don’t understand at all. The DHCP client is set, but it seems never get any configuration. I suspect that may get somehow via the PPPoE interface, but that cannot be configured as a DHCP client. It is visible in the IP address list as a dynamic address.
When I try to set the static routes, ping test is always failing, so my PCC connection not gonna work. As usual, my provider’s helpdesk is useless, they cannot provide me the valid GW address.
Other problem is the NS resolution. There are 2 NS servers for each provider, added in DNS and DHCP DNS server list too. From the terminal the DNS resolution works, but not from any DHCP client computer.
Here is the router config:
# 2024-05-19 21:32:21 by RouterOS 7.14.3
# software id = 5QSS-81G1
# model = C53UiG+5HPaxD2HPaxD
add name=bridge1
set [ find default-name=ether4 ] name=ether4-WAN-O2
set [ find default-name=ether5 ] mac-address=04:8D:38:62:E9:A8 name=ether5-WAN-NDC
/interface vlan
add interface=ether4-WAN-O2 name=vlan1-O2 vlan-id=848
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan1-O2 max-mru=1492 max-mtu=1492 name=pppoe-O2 user=**
add name=dhcp_pool0 ranges=192.168.88.10-192.168.88.50
add address-pool=dhcp_pool0 interface=bridge1 name=dhcp1
/ip smb users
/routing table
add disabled=no fib name=To-O2
add disabled=no fib name=To-NDC
add bridge=bridge1 interface=wifi2
add bridge=bridge1 interface=wifi1
set udp-timeout=10s
add address=192.168.88.0/24 interface=bridge1 network=192.168.88.0
/ip dhcp-client
add add-default-route=no interface=ether5-WAN-NDC
add add-default-route=no interface=ether4-WAN-O2
add address=192.168.88.0/24 dns-server=\
160.218.161.54,194.228.41.65,176.74.128.10,176.74.128.11 gateway=192.168.88.1
set servers=160.218.161.54,194.228.41.65
/ip firewall mangle
add action=accept chain=prerouting dst-address-list=10.74.200.34/28 in-interface=bridge1
add action=accept chain=prerouting dst-address-list=10.233.23.0/24 in-interface=bridge1
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=ether5-WAN-NDC new-connection-mark=NDC-Mark passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=ether4-WAN-O2 new-connection-mark=O2-Mark passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=bridge1 new-connection-mark=O2-Mark \
passthrough=yes per-connection-classifier=both-addresses:2/0
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=bridge1 new-connection-mark=NDC-Mark \
passthrough=yes per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=NDC-Mark in-interface=bridge1 new-routing-mark=To-NDC passthrough=yes
add action=mark-routing chain=prerouting connection-mark=O2-Mark in-interface=bridge1 new-routing-mark=To-O2 passthrough=yes
add action=mark-routing chain=output connection-mark=NDC-Mark new-routing-mark=To-NDC passthrough=yes
add action=mark-routing chain=output connection-mark=O2-Mark new-routing-mark=To-O2 passthrough=yes
add action=masquerade chain=srcnat out-interface=ether5-WAN-NDC
add action=masquerade chain=srcnat out-interface=pppoe-O2
#ping OK
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/32 gateway=10.74.200.33 pref-src="" routing-table=To-NDC scope=30 suppress-hw-offload=no target-scope=10
#Ping KO
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/32 gateway=10.233.23.92 pref-src="" routing-table=To-O2 scope=30 suppress-hw-offload=no target-scope=10
#Ping OK
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/32 gateway=10.74.200.33 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
#Ping KO
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/32 gateway=10.233.23.92 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
Thank you in advance!
