Per connection limit per time interval with burst on Mikroti
Hello, i’m moving from a FreeBSD-based router to a RouterBoard. I’m currently on 6.0rc11
I’ve been trying to implement anti-ddos protection for my servers, but I can’t quite figure it out. Is there a way to mimic this set of PF rules?:
anti ddos from 80 port
table persist
block in quick from
pass in quick on $AFF proto tcp from any to 81.200.12.10 port 80 keep state
(> max-src-conn 70, max-src-conn-rate 40/5> , overload flush)
pass in quick on vlan500 proto tcp from any to 81.200.12.10 port 80 keep state
To my current understanding, Mikrotik cannot do that (connlimit per time interval per ip and with burst)?
http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/Filter
Read about ‘dst-limit’ matcher.
HTH,
I read about it, but it does not solve my problem since it doesn’t differentiate between separate source IPs. I mean it doesn’t support a separate counter for each source IP, it’s a global counter.
And also it limits packets per time interval, not connections per time interval (although I could workaround it with tracking SYNs).
If you set limit by src and dest then it will.
hm, do I understand this correctly, that this rule:
add action=jump chain=forward connection-state=new dst-port=80 jump-target=anti-ddos protocol=tcp
add action=return chain=anti-ddos dst-limit=40/5s,70,src-and-dst-addresses/1h
will match from a single IP up to 70 new connections (burst) and then 40 new connections in the interval of 5 seconds. The pair src-addr/dst-addr expires in 1 hour (I don’t really understand what happens after it expires).
Will this work as I describe?
IMHO it should be:
add action=drop chain=anti-ddosLine 2 allows up to 40 new connections in the interval of 5 seconds, line 3 explicitly drops packets if number of new connections is above 40/5s.
This post should be also useful for you in case of DDoS attack.
All counters for this particular src-addr/dst-addr pair are deleted and measurement starts from beginning.
HTH,
