PHP API and /interface/monitor-traffic
Hi. I’m using code below to monitor traffic.
BUT it show same information for all interfaces even if only one interface has clients.
require('mikrotik.php');
$API = new routeros_api();
$API->debug = false;
if ($API->connect('192.168.5.6', 'user', 'pass')) {
   //$API->write('/interface/wireless/registration-table/getall');
   $API->write('/interface/monitor-traffic');
   $API->write('=interface=wlan1');
   $ARRAY = $API->read();
   print_r($ARRAY);
   $API->write('=interface=wlan11');
   print_r($ARRAY);
   $API->write('=interface=wlan2');
   print_r($ARRAY);
   $API->write('=interface=wlan21');
   print_r($ARRAY);
   $API->disconnect();
at first, seems like you send “/interface/monitor-traffic” and “=interface=wlan1” as different commands. aren’t there second parameter in $API->write() function, that should be set to false (?) if there are more parameters for the command?
then, ‘monitor-traffic’ has continuous output, you should use ‘=once=’ parameter to have a single result
Thank you.
How can I send “once”?
$API->write('/interface/monitor-traffic',false);
$API->write('=interface=wlan1',false);
$API->write('=once');
as I said, you should use =once= - parameter name should be ended by ‘=’ sign
Can you please share your whole code including the mikrotik.php
<?php
 * RouterOS PHP API class v1.6
 * Author: Denis Basta
 * Contributors:
 *    Nick Barnes
 *    Ben Menking (ben [at] infotechsc [dot] com)
 *    Jeremy Jefferson (http://jeremyj.com)
 *    Cristian Deluxe (djcristiandeluxe [at] gmail [dot] com)
 *    Mikhail Moskalev (mmv.rus [at] gmail [dot] com)
 * http://www.mikrotik.com
 * http://wiki.mikrotik.com/wiki/API_PHP_class
class RouterosAPI
    var $debug     = true; //  Show debug information
    var $connected = true; //  Connection state
    var $port      = 8728;  //  Port to connect to (default 8729 for ssl)
    var $ssl       = false; //  Connect using SSL (must enable api-ssl in IP/Services)
    var $timeout   = 3;     //  Connection attempt timeout and data read timeout
    var $attempts  = 5;     //  Connection attempt count
    var $delay     = 3;     //  Delay between connection attempts in seconds
    var $socket;            //  Variable for storing socket resource
    var $error_no;          //  Variable for storing connection error number, if any
    var $error_str;         //  Variable for storing connection error text, if any
    /* Check, can be var used in foreach  */
    public function isIterable($var)
        return $var !== null
                && (is_array($var)
                || $var instanceof Traversable
                || $var instanceof Iterator
                || $var instanceof IteratorAggregate
     * Print text for debug purposes
     * @param string      $text       Text to print
     * @return void
    public function debug($text)
        if ($this->debug) {
            echo $text . "\n";
     * @param string        $length
     * @return void
    public function encodeLength($length)
        if ($length < 0x80) {
            $length = chr($length);
        } elseif ($length < 0x4000) {
            $length |= 0x8000;
            $length = chr(($length >> 8) & 0xFF) . chr($length & 0xFF);
        } elseif ($length < 0x200000) {
            $length |= 0xC00000;
            $length = chr(($length >> 16) & 0xFF) . chr(($length >> 8) & 0xFF) . chr($length & 0xFF);
        } elseif ($length < 0x10000000) {
            $length |= 0xE0000000;
            $length = chr(($length >> 24) & 0xFF) . chr(($length >> 16) & 0xFF) . chr(($length >> 8) & 0xFF) . chr($length & 0xFF);
        } elseif ($length >= 0x10000000) {
            $length = chr(0xF0) . chr(($length >> 24) & 0xFF) . chr(($length >> 16) & 0xFF) . chr(($length >> 8) & 0xFF) . chr($length & 0xFF);
        return $length;
     * Login to RouterOS
     * @param string      $ip         Hostname (IP or domain) of the RouterOS server
     * @param string      $login      The RouterOS username
     * @param string      $password   The RouterOS password
     * @return boolean                If we are connected or not
    public function connect($ip, $login, $password)
        for ($ATTEMPT = 1; $ATTEMPT <= $this->attempts; $ATTEMPT++) {
            $this->connected = false;
            $PROTOCOL = ($this->ssl ? 'ssl://' : '' );
            $context = stream_context_create(array('ssl' => array('ciphers' => 'ADH:ALL', 'verify_peer' => false, 'verify_peer_name' => false)));
            $this->debug('Connection attempt #' . $ATTEMPT . ' to ' . $PROTOCOL . $ip . ':' . $this->port . '...');
            $this->socket = @stream_socket_client($PROTOCOL . $ip.':'. $this->port, $this->error_no, $this->error_str, $this->timeout, STREAM_CLIENT_CONNECT,$context);
            if ($this->socket) {
                socket_set_timeout($this->socket, $this->timeout);
                $this->write('/login');
                $RESPONSE = $this->read(false);
                if (isset($RESPONSE[0]) && $RESPONSE[0] == '!done') {
                    $MATCHES = array();
                    if (preg_match_all('/[^=]+/i', $RESPONSE[1], $MATCHES)) {
                        if ($MATCHES[0][0] == 'ret' && strlen($MATCHES[0][1]) == 32) {
                            $this->write('/login', false);
                            $this->write('=name=' . $login, false);
                            $this->write('=response=00' . md5(chr(0) . $password . pack('H*', $MATCHES[0][1])));
                                $this->connected = true;
                                break;
                fclose($this->socket);
            sleep($this->delay);
        if ($this->connected) {
            $this->debug('Connected...');
        } else {
            $this->debug('Error...');
        return $this->connected;
     * Disconnect from RouterOS
     * @return void
    public function disconnect()
        // let's make sure this socket is still valid.  it may have been closed by something else
        if( is_resource($this->socket) ) {
        $this->debug('Disconnected...');
     * Parse response from Router OS
     * @param array       $response   Response data
     * @return array                  Array with parsed data
    public function parseResponse($response)
        if (is_array($response)) {
            $PARSED      = array();
            $CURRENT     = null;
            $singlevalue = null;
            foreach ($response as $x) {
                if (in_array($x, array('!fatal','!re','!trap'))) {
                    if ($x == '!re') {
                        $CURRENT =& $PARSED[];
                    } else {
                        $CURRENT =& $PARSED[$x][];
                } elseif ($x != '!done') {
                    $MATCHES = array();
                    if (preg_match_all('/[^=]+/i', $x, $MATCHES)) {
                        if ($MATCHES[0][0] == 'ret') {
                            $singlevalue = $MATCHES[0][1];
                        $CURRENT[$MATCHES[0][0]] = (isset($MATCHES[0][1]) ? $MATCHES[0][1] : '');
            if (empty($PARSED) && !is_null($singlevalue)) {
                $PARSED = $singlevalue;
            return $PARSED;
        } else {
            return array();
    public function parseResponse4Smarty($response)
            $PARSED      = array();
            $CURRENT     = null;
                    if ($x == '!re') {
                    } else {
                    $MATCHES = array();
            foreach ($PARSED as $key => $value) {
                $PARSED[$key] = $this->arrayChangeKeyName($value);
            return $PARSED;
        } else {
            return array();
     * Change "-" and "/" from array key to "_"
     * @param array       $array      Input array
     * @return array                  Array with changed key names
    public function arrayChangeKeyName(&$array)
        if (is_array($array)) {
            foreach ($array as $k => $v) {
                $tmp = str_replace("-", "_", $k);
                $tmp = str_replace("/", "_", $tmp);
                if ($tmp) {
                    $array_new[$tmp] = $v;
                } else {
                    $array_new[$k] = $v;
            return $array_new;
        } else {
            return $array;
     * Read data from Router OS
     * @param boolean     $parse      Parse the data? default: true
     * @return array                  Array with parsed or unparsed data
    public function read($parse = true)
        $RESPONSE     = array();
        $receiveddone = false;
        while (true) {
            // Read the first byte of input which gives us some or all of the length
            // of the remaining reply.
            $BYTE   = ord(fread($this->socket, 1));
            $LENGTH = 0;
            // If the first bit is set then we need to remove the first four bits, shift left 8
            // and then read another byte in.
            // We repeat this for the second and third bits.
            // If the fourth bit is set, we need to remove anything left in the first byte
            // and then read in yet another byte.
            if ($BYTE & 128) {
                if (($BYTE & 192) == 128) {
                    $LENGTH = (($BYTE & 63) << 8) + ord(fread($this->socket, 1));
                } else {
                    if (($BYTE & 224) == 192) {
                        $LENGTH = (($BYTE & 31) << 8) + ord(fread($this->socket, 1));
                        $LENGTH = ($LENGTH << 8) + ord(fread($this->socket, 1));
                    } else {
                        if (($BYTE & 240) == 224) {
                            $LENGTH = (($BYTE & 15) << 8) + ord(fread($this->socket, 1));
                        } else {
                            $LENGTH = ord(fread($this->socket, 1));
            } else {
                $LENGTH = $BYTE;
            $_ = "";
            // If we have got more characters to read, read them in.
            if ($LENGTH > 0) {
                $_      = "";
                $retlen = 0;
                while ($retlen < $LENGTH) {
                    $toread = $LENGTH - $retlen;
                    $_ .= fread($this->socket, $toread);
                    $retlen = strlen($_);
                $RESPONSE[] = $_;
                $this->debug('>>> [' . $retlen . '/' . $LENGTH . '] bytes read.');
            // If we get a !done, make a note of it.
            if ($_ == "!done") {
                $receiveddone = true;
            $STATUS = socket_get_status($this->socket);
            if ($LENGTH > 0) {
                $this->debug('>>> [' . $LENGTH . ', ' . $STATUS['unread_bytes'] . ']' . $_);
            if ((!$this->connected && !$STATUS['unread_bytes']) || ($this->connected && !$STATUS['unread_bytes'] && $receiveddone)) {
                break;
        if ($parse) {
            $RESPONSE = $this->parseResponse($RESPONSE);
        return $RESPONSE;
     * Write (send) data to Router OS
     * @param string      $command    A string with the command to send
     * @param mixed       $param2     If we set an integer, the command will send this data as a "tag"
     *                                If we set it to boolean true, the funcion will send the comand and finish
     *                                If we set it to boolean false, the funcion will send the comand and wait for next command
     *                                Default: true
     * @return boolean                Return false if no command especified
    public function write($command, $param2 = true)
        if ($command) {
            $data = explode("\n", $command);
            foreach ($data as $com) {
                $com = trim($com);
                fwrite($this->socket, $this->encodeLength(strlen($com)) . $com);
                $this->debug('<<< [' . strlen($com) . '] ' . $com);
            if (gettype($param2) == 'integer') {
                fwrite($this->socket, $this->encodeLength(strlen('.tag=' . $param2)) . '.tag=' . $param2 . chr(0));
                $this->debug('<<< [' . strlen('.tag=' . $param2) . '] .tag=' . $param2);
            } elseif (gettype($param2) == 'boolean') {
                fwrite($this->socket, ($param2 ? chr(0) : ''));
            return true;
        } else {
            return false;
     * @param string      $com        A string with the command to send
     * @param array       $arr        An array with arguments or queries
    public function comm($com, $arr = array())
        $count = count($arr);
        $this->write($com, !$arr);
        $i = 0;
        if ($this->isIterable($arr)) {
            foreach ($arr as $k => $v) {
                switch ($k[0]) {
                    case "?":
                        $el = "$k=$v";
                        break;
                    case "~":
                        $el = "$k~$v";
                        break;
                    default:
                        $el = "=$k=$v";
                        break;
                $last = ($i++ == $count - 1);
                $this->write($el, $last);
        return $this->read();
     * Standard destructor
     * @return void
    public function __destruct()
        $this->disconnect();
