Ping drops and high responce..
I hv pt to pt link upto 22km distance and some time suddenly facing problem like remote client stops pinging while checking the status in Registered client it shows 1 ( connected ) and signal also -69/-70 , with same status while checking with freq. usage or scaning from client side no other link is comming in scan or all freq. shows 0.0 usage , how to resolve this or what exactly the problem, same time changing of freq. is also not resolving the issue , and changing freq. the signal will -70 / 0 dbm , links shows up but no ping
thanks
Are you using compression?
No , not using compression ..
Can you MAC ping when it goes down?
I have the same problem here :frowning:
well, i dont know what makes the ping go so high, i have configured 2 Mk’s, making a link from a city to another, something about 4 km, when i get in the mk and ping each node, its everything normal.
But, my problem its with the Mikrotik as AP, cause, the clients gets a high latency, and i dont know what’s.
Resuming, when i got to a cliente, conneced in MK AP, and ping this AP, the latency goes high, something about 1k ms sometimes.
Can anybody help me?
OBS: i’ve checked the ACK, and its everything normal, its in 30, all clients has perfect sinal.
Att, Alysson
Need to provide more information about your software and hardware setup.
well, i just dont have how to post here, my configs, cause its in another city, but, my hardware its a RouterBoard 532R5 with two Mini PCI EMP 8602 PLUS Card 630mWatts IEE802.11a/b/g
Soon i will post my software setups
well, as i´ve promised here the software setup ^^
0 R name=“wlan1” mtu=1500 mac-address=00:02:6F:4B:40:B0 arp=enabled
disable-running-check=no interface-type=Atheros AR5413
radio-name=“00026F4B40B0” mode=ap-bridge ssid=“SDNET” area=“”
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=2412 band=2.4ghz-b scan-list=default rate-set=configured
supported-rates-b=1Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=30 tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=no default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms hw-retries=15 preamble-mode=both
compression=no allow-sharedkey=no
1 R name=“wlan2” mtu=1500 mac-address=00:02:6F:4B:40:B8 arp=enabled
radio-name=“00026F4B40B8” mode=bridge ssid=“link” area=“”
frequency=5300 band=5ghz scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
54Mbps
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=dynamic
wds-default-bridge=wds wds-default-cost=100 wds-cost-range=50-150
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
hide-ssid=yes security-profile=default disconnect-timeout=3s
wlan1 interface its that i´m having problem, its where the clients connect, wlan2 its my backbone interface, with this its everything ok
is there something wrong??? i need help fast
Att. Alysson
Is there a reason why you have changed your ACK from dynamic?
well, it was just a test, but every client has a ack in 30, as i’ve said, theres no signal problem in my clients
tell me one thing that im not sure, this -xxdbm, if i have someone with -95dbm its bad and -50dbm its better???
You only see -95 on an idle radio that isn’t moving any traffic
