Ping is possible, no internet access (http)
Hi guys,
I have a RBD52G with default configuration which I wanted to connect to the internet via a Fritzbox.
When I’m in the FBs LAN (192.168.99.0/24) I can access the internet properly.
When I’m in the MTs LAN (192.168.1.0/24), I can ping addresses (from both WiFi client and routers terminal) but I can’t open any website. I also can access my FB
In Quick Set, NAT is activated, so in the firewall section masquerade is enabled on the srcnat chain with out.interface must WAN.
With /tool traceroute on google.com the last shown IP (142.251.209.142) belongs to Google…
[admin@MikroTik] > /tool traceroute
address: google.com
ADDRESS LOSS SENT LAST AVG BEST WORST STD-DEV STATUS
1 192.168.99.1 0% 319 0.3ms 0.3 0.3 0.9 0.1
2 91.65.154.xxx 0% 319 9.3ms 21.1 8.2 143.5 17.2
3 83.169.179.22 0% 319 12ms 21.2 5.9 128.4 18
4 88.134.193.162 0% 319 8.9ms 22.4 7.9 187.4 19.6
5 145.254.3.196 0% 319 12.9ms 23.9 8.1 171.9 20
6 145.254.2.215 0% 319 16ms 27.1 13.3 99.2 15.7
7 145.254.2.215 0% 319 31ms 27 13.4 121.9 17.5
8 72.14.216.250 0% 319 15.8ms 26.3 12.9 118.1 17.9
9 216.239.63.19 0% 319 18ms 26.9 12.9 144.1 19.3
10 142.251.244.105 0% 319 15ms 26 12.9 97 14.6
11 142.251.209.142 0% 319 16.5ms 26 12 109.2 16.7
So my question is: What do I need to do / configure to be able to access the internet properly?
I’m quite new to Mikrotik and routerOS, so any help is highly appreciated!
Many thanks in advance and best regards
Stefan
You are fired quickset is a word most people have set on their forum settings to then ignore all posts from a user…
Also the lack of a config file is a real turn-off
/export file=anynameyouwish (minus serial number and any public wanip Info)
Thank you for your very quick (and honest) reply.
Here’s my config:
# oct/26/2022 21:18:49 by RouterOS 6.49.6
# software id = 1758-TR55
# model = RBD52G-5HacD2HnD
# serial number = XXXXXXXXX
add admin-mac=DC:2C:6E:E9:71:DC auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=germany disabled=no distance=indoors frequency=auto installation=\
    indoor mode=ap-bridge ssid=XXXXXXXXX wireless-protocol=802.11 wps-mode=\
    disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country=germany disabled=no distance=indoors frequency=\
    auto installation=indoor mode=ap-bridge ssid=XXXXXXXXX wireless-protocol=\
    802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik wpa-pre-shared-key=XXXXXXXXX \
    wpa2-pre-shared-key=XXXXXXXXX
/ip hotspot profile
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
    192.168.1.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.1.0/24 comment=defconf dns-server=192.168.88.1 gateway=\
    192.168.1.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/system clock
/tool mac-server
/tool mac-server mac-winbox
I found the error - the old DNS gateway was still in use (192.168.88.1). Sorry for this unnecessary issue and a nice evening to all!
