ping - missing routing-table
Hello
I have a problem with Mikrotik version 7
In versions 6 and earlier, when we wanted to ping from the ping section based on a specific Route Table, there was a Route Table option.
https://filetransfer.io/data-package/Peq9wJl0#link
But in Mikrotik version 7, this option has been removed from the ping section and I cannot ping the items that I have defined for Mangle.
Does anyone have a solution?
See here:
http://forum.mikrotik.com/t/how-to-use-ping-with-multiple-routing-marks-in-ros-version-7/175887/3
http://forum.mikrotik.com/t/ping-missing-routing-table/155004/1
HI
I did not find a solution
Did you look? The second post in each of the topics above gives the answer!
Use the vrf parameter instead of routing-table. Create VRFs without interfaces using “interfaces=none” parameter.
