I recently upgraded my computer form Windows XP Pro 32 bits to Windows 7 Ultimate 64 bits.
I have re-installed Dude and imported the config file…
Everything is working well except that all devices are reported as down…
Firewall not activated…and SNMP pooling is working
In other words, make sure your Windows account has administrative privileges, or simply disable all those annoying warning messages, firewalls, antiviruses etc.
Disabling UAC is needed only for creating “The Dude Server” service (menu Local server → as service).
After that, Dude can be running with UAC enabled connecting to Dude server running as service.
(Tested on Win 7 64-bit, Dude 4.0beta3).
I also have same prob. I disable the UAC , firewall, and aLso my antivirus . But I still have prob. When I run dude server everyThing is fine. But after a while it has same prob.
Any suggestions!??!
