Ping or floodping
So i have problem figuring out what to use is it either ping or floodping.
main goal is to get avg-rtt on a routing table
Problem 1: Ping can do the routing table but return value is always ping counts
Problem 2: Floodping can return avg-rtt ms but you cant select routing table
:local addr 8.8.8.8;
:local ms 100;
:local avg;
/tool flood-ping $addr count=10 routing-table=m2 do={
	:if ($sent = 10) do={
	:set avg $"avg-rtt"
:if ($avg >= $ms) do={
	/ip route disable [find where routing-mark=m2 distance=1];
} else={
	/ip route enable [find where routing-mark=m2 distance=1];
/tool flood-ping $addr count=10 routing-table=m2 this line would make it perfect but unfortunately flood-ping doesn’t have routing table.
any ideas how to pull this off?
Hi anyone!
Is there any news about topic-starter question?
Yes, your resurrecting post.
funny, but useless
