Ping problem when wlan connected to bridge
I have a problem with hap ac. When wlan interface works as stand alone interface (without bridge) then everything works fine. Problem is when wlan gets connected as bridge port. Then is situation as follows:
  • ping from client to router is ~1ms
  • ping from router to client is somewhere between 1ms and 200ms.
  • ping from client to client on the same interface is, if not lost, then around 1000-2000ms.
When i say “client” I mean everything: computers (win/osx, phones, tablets…).
I’ve tried every possible combination of configuration for bridge and ports (even tried with only one port) and it does not work. As soon as I disconnect wlan from bridge then everything works fine.
Any ideas? I tried with 6.36 and then with 6.34 but always same problem.
Thanks!
Simplify and work backwards. Disable all of your firewall rules as well as your NAT and Mangle. If you are stable at that point, enable one at a time to find out where your problem lies.
Well, this is brand new device. No fw or mangle rules. No load on device (only devices used for testing).
I’ve done some more testing this morning and bridge is only thing that makes problem.
So if anyone has some idea of how to configure bridge in order to work properly…? As i said, I tried every possible combination but problem is still there but maybe I missed something…
Test results in both directions…
From client to router:
PING 10.2.1.1 (10.2.1.1): 56 data bytes
64 bytes from 10.2.1.1: icmp_seq=0 ttl=64 time=2.912 ms
64 bytes from 10.2.1.1: icmp_seq=1 ttl=64 time=1.765 ms
64 bytes from 10.2.1.1: icmp_seq=2 ttl=64 time=1.170 ms
64 bytes from 10.2.1.1: icmp_seq=3 ttl=64 time=1.768 ms
64 bytes from 10.2.1.1: icmp_seq=4 ttl=64 time=1.736 ms
64 bytes from 10.2.1.1: icmp_seq=5 ttl=64 time=1.850 ms
64 bytes from 10.2.1.1: icmp_seq=6 ttl=64 time=1.007 ms
64 bytes from 10.2.1.1: icmp_seq=7 ttl=64 time=1.811 ms
64 bytes from 10.2.1.1: icmp_seq=8 ttl=64 time=1.182 ms
64 bytes from 10.2.1.1: icmp_seq=9 ttl=64 time=3.040 ms
64 bytes from 10.2.1.1: icmp_seq=10 ttl=64 time=1.897 ms
64 bytes from 10.2.1.1: icmp_seq=11 ttl=64 time=1.807 ms
64 bytes from 10.2.1.1: icmp_seq=12 ttl=64 time=1.036 ms
64 bytes from 10.2.1.1: icmp_seq=13 ttl=64 time=1.169 ms
64 bytes from 10.2.1.1: icmp_seq=14 ttl=64 time=1.736 ms
64 bytes from 10.2.1.1: icmp_seq=15 ttl=64 time=1.696 ms
64 bytes from 10.2.1.1: icmp_seq=16 ttl=64 time=1.832 ms
64 bytes from 10.2.1.1: icmp_seq=17 ttl=64 time=1.772 ms
64 bytes from 10.2.1.1: icmp_seq=18 ttl=64 time=1.260 ms
64 bytes from 10.2.1.1: icmp_seq=19 ttl=64 time=1.569 ms
64 bytes from 10.2.1.1: icmp_seq=20 ttl=64 time=1.775 ms
64 bytes from 10.2.1.1: icmp_seq=21 ttl=64 time=1.852 ms
From router to client:
SEQ HOST                                     SIZE TTL TIME  STATUS
   20 10.2.1.99                                  56  64 1ms
   21 10.2.1.99                                  56  64 70ms
   22 10.2.1.99                                  56  64 1ms
   23 10.2.1.99                                  56  64 1ms
   24 10.2.1.99                                  56  64 1ms
   25 10.2.1.99                                  56  64 1ms
   26 10.2.1.99                                  56  64 77ms
   27 10.2.1.99                                  56  64 101ms
   28 10.2.1.99                                  56  64 28ms
   29 10.2.1.99                                  56  64 50ms
   30 10.2.1.99                                  56  64 70ms
   31 10.2.1.99                                  56  64 1ms
   32 10.2.1.99                                  56  64 18ms
   33 10.2.1.99                                  56  64 40ms
   34 10.2.1.99                                  56  64 70ms
   35 10.2.1.99                                  56  64 91ms
   36 10.2.1.99                                  56  64 111ms
   37 10.2.1.99                                  56  64 28ms
   38 10.2.1.99                                  56  64 50ms
   39 10.2.1.99                                  56  64 71ms
    sent=40 received=40 packet-loss=0% min-rtt=1ms avg-rtt=51ms max-rtt=111ms
This was done at the same time…
As I already said. Changing client device does not help. This was on 5ghz interface but it is the same on 2,4 as long as interface is on bridge. I tried to add virtual interface which would not be part of bridge and it works then correctly. So, the only problem seems to be the bridge…
can you please post the output of
/interface export compact
and
/ip firewall filter export compact
I bet he didn’t transfer the IP configuration from the wlan interface to the bridge interface…
Sent from my SM-G920I using Tapatalk
