I have the following two ip schemes and i need them to be able to communicate with eachother. (ping). I can ping an ip from the 10.20.1.1 network to the 10.10.1.1 network but not the other way around.
I need the two networks to work together for my phone system.
Ether2
10.10.1.1/24
10.10.1.0
Ether3
10.20.1.1/24
10.20.1.0
Rudios
September 19, 2013, 5:03am
2
Maybe a firewall on the local system of a firewall filter rules set on the mikrotik
Yah, and ive loooked through the firewall rules. Cant seem to find anything.
doush
September 19, 2013, 1:19pm
4
ip address export
ip route export
Copy and paste the output from both routers so we can see your config
add address=10.10.1.1/24 comment=“Innova Office LAN” interface=“E2 Innova LAN”
network=10.10.1.0
add address=10.20.1.1/24 comment=“Innova VOIP LAN” interface=“E3 VOIP LAN”
network=10.20.1.0
add address=172.16.1.1/24 comment=“Web LAN” interface=“E5 WEB LAN” network=
172.16.1.0
add distance=1 gateway=74.87.126.209 scope=255
add distance=1 dst-address=10.20.1.1/32 gateway=“E2 Innova LAN”
Rudios
September 19, 2013, 3:22pm
6
The static route for the 10.20.1.0 segment is not needed. And seen from your screenshot it looks like the interface having 10.20.1.1 address is down.
