Please Continue Supporting WinBox 3 — Many of Us Prefer the Classic UI
You can sort this way also in WB4. Just hold shift button while clicking the column headers. It is the multi-column sort.
Haha, you saved me from a lot of headaches! Thanks a lot!
Although this was just one example, I shouldn't have to visit the forum to find out about something like this. Having used WinBox 4 since its very first release, I should have been able to figure this out on my own. The fact that I couldn't is evidence in itself that something about the UX isn't quite right.
It's already documented in the manual:
Not to mention that SHIFT+Click on column header is quite common for desktop applications supporting multi-column sorting. WinBox 3 implementation is actually an outlier. That's why WinBox 3 only supports two columns, while WB4 and others allows an arbitrary numbers of columns to be sorted.
It's impossible. ShitBox 4 goes wrong from the very beginning. Some basic things are almost unfixable - bad performance, reckless RAM usage, Win 7 support (don't tell me it's "old" and stuff like that), UI should be remade from zero. I don't even talk about tens of other issues. So, personally I think it doesn't worth a single AI token or human minute to spend on it.
Yet, some of us have almost none of those issues. 1 to 2 second start, zero delay, crisp, sharp, contrasty . . . . and on 12 year old laptop hardware with mediocre graphics.
Why?
1-2 sec start is ok? No comment.
Zero delay? Find and read my post in WB4 topic about Ethernet/SFP type interface subwindow opening delay.
Crisp? Right, any :poop: is crisp at first.
Sharp, contrasty? :laughing: good joke...
May be you also think this forum looks good without tweaking?
1 to 2 second start is outstanding, and consistent with just about everything else, so no, not an issue at all.
Never noted any delay loading screens/windows - SFP or otherwise.
No issues with sharpness on this forum either - razor sharp on Android and Linux (I don't use Whinders . . . )
White on black - perhaps a joke to you, but I call it fact. Couldn't get any higher contrast . . .
Zero font fuzz, artifacts, rainbows, efc. (discussed in other threads), but again, no potential for potentially bad Windows font rendering either.
Well, Shift is strictly reserved for knifing people. I don't see any other reason to press it.
It is a well established pattern on data grids in software. I don't like it either, because it is not very obvious if you don't already know it. I one suggested to add a info-icon or toolip on the table colums to indicate/inform user about the possibility of shift+click.
But to support your point: is ctrl+v and ctrl+c something magically coming to your mind? No, it is not. But the very difference is: in 99% of case where you can ctrl+v, you also can right-klick and use "paste" from a graphical menu.
So I'd suggest to Winbox developer 2 probable approaches:
  • add tooltip or info icon near the table sort icon for in-place info
  • add sorting settings dialog, placed in the menu where currently the visible columns can be configured.
Please excuse my ugly nad not accurate mockups. they're AI slopped :wink: But to visualize the idea.
The shortcut links and tooltips would help a lot, especially the tooltips. Most users won't actively search for these features, so tooltips are a great way to make them discoverable and help users understand what they do without having to look them up. However, as you already explained, these are shortcuts rather than the main functionality. When I use WinBox, it's primarily because of the mouse-driven workflow and the GUI, not because of keyboard shortcuts.
It is not a keyboard shortcut. It is a keyboard mouse behaviour modifier. IIRC holding ctrl while usenthe mouse for selection allows column selection when working with tables. or using ctrl to do multi file-selection in a file browser on your OS. There are many different ones, some even with alt or shift.
tl;dr
alt/shift/ctrl+ mouse is very common modifier combination in many applications. Don't act like WB does something very unique or awkward here.
My main concern isn't what these interactions are technically called. I'm not a developer, so I might not use the correct terminology. The issue is discoverability: these behaviours aren't visible to the user. Tooltips would help users discover them naturally without having to search for documentation or already know they exist.
As you mentioned, some of these options are also available through the right-click context menu, so users who prefer that workflow can use it instead. My point is simply that making these interactions more discoverable would improve the overall UX.
It no longer receive updates, and be EOL for a decade. So it to configure other people's networks is itself the definition of supply chain risks.
Good news is MikroTik made WB4 cross-platform... so you can install Linux on the older laptop and still have WinBox on OS that can receives security updates.
What about MY OWN networks? :astonished_face:
I think I'm saying Windows 7 support may not be the hill to die on here. That WB4 is porky compared to native WB3, is more fair. The "I want to use an OS that the maker does not support and does not patch" case is a loser. And yeah if your "professional" (e.g. getting paid to manage networks)... using unpatched OS, perhaps with patched EXE downloaded from a forum... is questionable practice at best, maleficence at worse.
Sure it may not a hill to die on, but making a little resistance may be useful.
In my experience OS compatibility (please read as lack of) on MS various versions of Windows is rarely due to actual limitations but rather on laziness or sloppiness of the developers that do not take into account the possibility that someone may not be running the latest and bestest MS OS.
If you prefer, most of the times these OS compatibility issues are artificial, whether intentional or accidental is another thing.
I will repeat how I find very convenient to manage MY networks an old laptop, 11" screen, that runs barely Windows 7 (Starter edition if you want to know) due to very limited oomph, because it is 2/3 in size of a 15.4" one.
It is not like Winbox 3 or 4 is (or 5 will be) a real-time 3D animation rendering engine, it is a stupid program to change a few settings, it could probably be re-written as console only and run under DOS or CP/M.
Personally, and of course you and your bot or your bot and its human (as it likes to call you) will disagree, I find programmers that manage to write simple, low resource, "universal" programs to be far more capable than those that throw everything at the latest compiler with default options and call it a day.
Going that far back, you also have to consider the pretty much complete abandonment of 32 bit systems . . .
So, unless WebFig starts demanding some exotic browser extensions, I think that it and ssh shoud/will become the path for old platforms.
If RouterOS would support tmux I wouldn't care fore Winbox not a second at all. :thinking: I guess I am going to file a feature request :slightly_smiling_face:
The MikroTik business objective was a cross-platform admin tool. And Qt is entirely reasonable, given that requirement. Importantly, RouterOS config is tightly-bound with "winbox", since essentially config is persisted in file-based form same as wire protocol. This means if you change stuff, there aren't levels of abstraction between, which limits new features... so MikroTik be left maintaining changes in two clients, which I suspect went into the decision to make a cross-platform WinBox was in part drive to avoid maintaining two codebases.
But at its core the fact that RouterOS is very efficient. And I'd bet most of WB4 is generated from using lex/yacc like schemes to get the QML. So once again the "engineers are stupid" isn't the issue, the WB3 decision belongs with "management" who make prioritization decisions.
I never said that the engineers are stupid.
I said that smarter or more capable ones do exist and that personally I like them better.
And why the decision was taken It Is an altogether different topic.
Independently from the reasons why, a program that after two years of development has still several bugs and makes a large part of the users unhappy cannot be declared as a success.
The individual programmers that write It have their own part of responsabilities, but of course the main issues are in the management.
This is comparable to Microsoft Bob, the only good thing that came from It was Comic Sans.
But from Winbox 4 the only thing that can come out Is learning how to NOT render a font, and I don't believe - as a few people are arguing - that the faults are entirely in QT that Is used in tens or hundreds of GUI programs without needing ridiculous adjustments.
