Please Continue Supporting WinBox 3 — Many of Us Prefer the Classic UI
I would like to ask MikroTik to reconsider its decision to move users away from the classic WinBox 3 interface and to continue maintaining WinBox 3 alongside WinBox 4.
I have been using WinBox for years, and one of the things I appreciate most about MikroTik is the simplicity and efficiency of its traditional management tools. WinBox 3 has a familiar, compact, and straightforward interface that makes navigating menus, managing interfaces, configuring VLANs, troubleshooting networks, and working across multiple routers quick and comfortable.
Unfortunately, with newer RouterOS versions, including RouterOS 7.25, older WinBox versions are no longer accepted. When I try connecting to my RB5009UG+S+ running RouterOS 7.25 using WinBox 3.43, I receive this error:
"ERROR: router requires newer winbox, please upgrade"
I understand that MikroTik needs to introduce new features, improve security, and support future RouterOS capabilities. However, I do not believe that introducing a new interface should require users to abandon the old one entirely.
My suggestion
Instead of discontinuing compatibility with WinBox 3, could MikroTik consider:
  1. Maintaining WinBox 3 alongside WinBox 4, with continued security fixes and compatibility updates.
  2. Allowing WinBox 3 to connect to newer RouterOS versions wherever technically possible, even if some new features are available only in WinBox 4.
  3. Offering a classic UI mode in WinBox 4 that closely reproduces the original WinBox 3 layout, navigation, spacing, and overall workflow.
  4. Giving users the choice between the classic and modern interfaces rather than forcing everyone to adopt the new design.
Why this matters
WinBox is not just another application for many of us. It is a tool we use daily to manage production networks, troubleshoot customer connectivity issues, configure routers, and perform time-sensitive maintenance.
Familiarity and workflow efficiency matter. Experienced administrators have developed muscle memory around the classic interface. A redesign can introduce unnecessary friction into tasks that were previously quick and intuitive.
I am not against progress or new features. I simply believe that users should have a choice in how they interact with their equipment.
MikroTik has built a strong reputation for giving network administrators powerful tools and flexibility. Continuing to support the classic WinBox interface would be consistent with that philosophy.
Could MikroTik please consider keeping WinBox 3 alive, or providing a genuine classic interface mode in WinBox 4?
I would also like to hear from other users who prefer WinBox 3. If enough administrators share this preference, perhaps MikroTik will reconsider offering both experiences.
Thank you.
Win Box 3 is the past. All functions are in the newer one.
you're still using windows 2000 or Ubuntu 12.04?
Just to share a view from the other perspective:
Contemporary admins sometimes do not even know what the real keyboard is :slight_smile: and their muscle memory is focused in their thumbs only. It is hard to use WB3 on phones or tablets.
I also like the minimalistic style of old version but the user base changes, the environment changes, funcionalities and needs change.
there is no need for winbox3, if you could just change winbox4 "skin" to winbox3.. there is lot of strange layouts, when login page [saved] layout looks different from [neighbors], when you need remove spaces so you can see more. w4 is good for small count of routers. But all is unsharp un blurry.. eh. On other side i love right side "quick" menu.. but all hate probably is just spacing, not sharp fonts, colors and not able to read long logs and lists without adjusting all settings.
Winbox does not run on Windows Server 2016 (old remote server)
Don’t write about things you don’t actually know.
It’s ridiculous to make such absolute statements.
Here is one prime example (in fact, a single line is enough to refute what you’ve written)
The drag-and-drop file feature found in Winbox 3 does not exist in Winbox 4.
So, with this one statement, I have just refuted what you wrote incontrovertibly and objectively.
Winbox 4, with its more cumbersome workflows,
wasted space,
buttons that required a single click in Winbox 3 but now take several,
ridiculous fonts with poor character rendering (regardless of the specific typefaces used),
it just looks awful, with "blur" everywhere, everything is wider and in bold,
everything is the same color;
previously, visual cues (including color) made it easy to distinguish between different elements.
In short, this isn't just a matter of a different skin;
it is fundamentally poorly designed and poorly thought out.
Couldn't agree more. RouterOS v7.24.5 is the last usable version for now.
What I like to know is where is a configuration in RouterOS that's set to minimum version!
MT ! Stop hiding settings !
I think the biggest issue with WinBox 4 is not simply the appearance of the interface. It is the impact on workflow efficiency.
For those of us managing hundreds of MikroTik routers in a day, small changes in the number of clicks required to complete common tasks make a significant difference.
For example, in WinBox 3, setting up a VPN or accessing a configuration was often straightforward, with the required options available through a familiar, compact interface. In WinBox 4, some workflows involve more navigation, dragging and dropping items, or additional clicks to accomplish what used to be a quick operation.
One extra click might seem insignificant when configuring one router. But when you repeat the same operation across dozens or hundreds of routers, the extra time adds up, and the workflow becomes slower.
We manage production networks, troubleshoot customer issues, configure VPNs, work with VLANs, and perform routine maintenance under time pressure. We need an interface optimized for speed and efficiency, not just a modern appearance.
I am not saying WinBox 4 is bad or that it should stop evolving. I am asking MikroTik to consider the needs of network administrators who spend hours every day managing large numbers of devices.
Please consider providing a Classic Mode or Compact Mode that preserves the familiar WinBox 3 navigation, minimizes unnecessary clicks and drag-and-drop interactions, and allows more information to be visible on screen.
For professional network administrators, usability is not just about personal preference. It directly affects productivity. @dang21000
Yes but ...
If you have to repeat that procedure hundreds of times then there is a need for any automation to prepare changes and pushing them out in one clik.
Today, after upgrading our first MikroTik router, we discovered that WinBox 3.43 is no longer supported.
None of our system administrators have switched to WinBox 4, as we strongly prefer the simplicity, compactness, and efficiency of the classic WinBox 3 interface.
Despite the critical security vulnerabilities, we have decided to suspend further RouterOS upgrades across our infrastructure due to this compatibility issue.
Please restore compatibility with WinBox 3.43.
We manage a large number of MikroTik devices, and maintaining access to the familiar, lightweight WinBox 3 interface is extremely important to our daily operations.
Security updates should not force administrators to abandon a proven and efficient management interface.
Thank you for considering this request.
welcome on the forum,
Your post implies that you have not tested any 7.25beta or rc version before upgrading your fleet to 7.25 as WB4 is mentioned in the changelog:
*) winbox - set minimal supported WinBox version to 4.3;
Is it true suspicion?
Your comment implies that users a required to be software testers. Not everyone lives here on the forum.
Did anyone find bugs as submitted them to MT?
Also, something that important as a tool to configure the os should have been listed first in the change log and maybe in bold too and not at the end of the change log. I do admit that I sometimes miss something because I do a quick scan of the change log looking for certain changes.
Also, Stable! Free of KNOWN BUGS.
But admins should read at least changelog before upgrade.
Additionaly they IMHO should test a software before installing it or just install it in their own lab.
@wfbuton: Bravo, very wise decision ... it's a sarcasm if some do not recognize that fact .... there is a saying "I'm cutting off my nose to spite my face"
@wfbuton: So no more updates? Never ever? Any changes to any OS or hardware platform are forbidden as admins do not like changes.
Car mechanics could say same way: no more fixing cars as we need a new size of a screwdriver and non standard open-end wrench that are not supposed to be so durable as the ones we use.
I'm not here to start a war and not everyone has a test lab and end users shouldn't be required to have one.
I have no grief about having to use WB4.
And yeah. If your a network admin you should read the change log.
Seems like after a few hours on WB4, "muscle memory" will learn the new one, and cease to be an argument, so I'm having a hard time with that argument.
(I've also never seen anything that was blurry in WB4, but then again, that may have a relationship/dependency on the underlying platform. ???)
And in fact,
if everyone had done this,
car manufacturers would stop producing light bulbs (LED or otherwise),
bolts,
and screws
in a hundred different versions and a thousand different sizes,
it’s a total nightmare.
I get that technology moves forward,
but what the hell is the point of making a hundred different types of bolts,
all requiring different tools to unscrew or tighten them,
when the required torque, length, and diameter are exactly the same?
It’s just idiotic.
It's not about having a test lab if you didn't noticed.
It's about daily admin duties and checking what you do in advance.
If you blindly implement changes then do not blame others that you have not read the manual/requirements when something stops working as you are acustomed to and no one promised that it would be working that way till the end of IT world or longer.
I'm not making a argument against that.
Consider also the screen used under the sun.
I can’t exactly haul a €2,000 handheld device or a 20-inch screen up a pylon just to get a decent view
not with the way they’ve designed WB4.
The person designing WB4 doesn’t actually use it for real work
they just sit in their chair every now and then.
I say "every now and then" because it takes months for reported bugs to even be acknowledged,
let alone fixed.
(Where’s the functional drag-and-drop? What are you actually doing? Just sitting around?)
And with that fancy Mac and a 40-inch curved monitor, it’s no wonder they need the text to be larger and in bold.
If they were developing it on a standard monitor, under the sun, on field, you can bet they’d get rid of all those unnecessary bells and whistles.
