Please help for for making our own build on Mikrotik
Can anyone help me in making my own build on mikrotik
not possible
according to his other post, http://forum.mikrotik.com/t/new-rb-models/25377/5 , I think he wants to customize RouterOS logos, etc.
how is that related to the original question?
to load one Linux distro onto another ‘Linux distro’? =) sounds a bit crazy %)
by “mikrotik” I understood “software” as in “my own software package in RouterOS”
if he means RouterBOARD, then original poster - please clarify
Yes, RouterBOARD and I am not a direct distributor of Mikrotik, but I am using it in large quantity and only the distributors who had done training is having the rights to change the routerboards name, and put their configuration on it like www.abc.com and new name to the RouterBOARD.
Basically some file format will be there, and please tell me some editor for opening .dpk file extension, because I am having one file which when I add in RouterBOARD, my setting comes on it(that I had explained above).
The similar linux based file I also want to create and use.
Now it will be clear to everyone, and I suppose my english is perfect, readable and understandable, allthough it is not my mother-tounge.
Please contact mikrotik support about this
