Hi im just learning in mikrotik hap lite version 6.45.4.
i just want a help..
configure it in hotspot its just simple to you but for me its hard.
im just learning…
im just learning…
Simple example https://wiki.mikrotik.com/wiki/Hotspot_server_setup
thank sir.. i have a question..
how can i direct the user on the hotspot portal by login in wifi?
If your configuration is correct the client will de redirected automatically to the hotspot page…
Update your ROS to the latest version as well…
thankyou sir
