**PLEASE HELP** Simple PPTP vpn client setup
I have been trying to get a simple VPN PPTP client setup on my x86 ROS router v6.7 but never got it to work.
I have setup a VPN PPTP client like this and it is connected
And then my router is already able to access the Internet using the following Masquerade rule
add action=masquerade chain=srcnat disabled=no out-interface=ether1
So, I just add one IP route rule like this, whenever I go to the IP 209.68.27.16, it will route thru the VPN I setup above
As simple as that, it didn’t work. So I add one more NAT rule like this
add action=masquerade chain=srcnat disabled=no out-interface=testvpn
And it still don’t work. I can go to any other website without problem, but when I try to access the site 209.68.27.16, it would just time out.
I have been messing with this for almost a month but still can’t get it to work, I would appreciate if anyone can give me a hand here.
Did you set up a route in the VPN server to your localnet ips in that VPN client?
The VPN server is a paid service, so I don’t own the VPN server. Something like this http://strongvpn.com/
I just try to setup my ROS router to route a specific IP thru the VPN tunnel.
I see. Did you add the masquerade as shown in the Mikrotik setup?
add chain=srcnat action=masquerade out-interface=testvpn
I have two masquerade rules:
add chain=srcnat action=masquerade disabled=no out-interface=ether1
add chain=srcnat action=masquerade disabled=no out-interface=testvpn
Is the VPN running?
/interface pptp-client
print
There should be an ‘R’ after the ‘0’ and before the name.
edit: Did you follow all the instructions? There are “/ip firewall mangle” rules also.
http://strongvpn.com/setup_mikrotik_pptp.shtml
Yes, VPN is running, and I use iphone PPTP vpn connect and it works just fine. So, the VPN server itself is working.
I tried to use the mangle rules at the very beginning, but it never works. So, instead of using mangle rules to do marking, I just decide to make it simpler, just route on a specific IP to the testvpn. But then, I found out the “Route List” never work on x86 ROS router in the first place. I was using v5.24 and later upgrade to v6.7, but it never works… And thats why I have been messing with this VPN client setup for more than 1 month.
My route list has always worked, but I don’t use an X86 version.
Maybe you should post your entries in “/ip route”. It appears the recommended mangle rule sends everything (default route) through the VPN connection.
Here is the /ip route print
here is the interface
Can you ping 192.168.120.1?
Nope, I ping directly on ROS router terminal
[admin@MikroTik] /ip firewall nat>> /ping 192.168.120.1
HOST SIZE TTL TIME STATUS
192.168.120.1 timeout
sent=5 received=0 packet-loss=100%
Then you have a problem there. You should be able to ping the VPN gateway. Maybe you should contact strongvpn tech support.
I don’t use strongvpn, I use strongvpn as an example, but I have tried 2 different VPN company, and I can’t ping none of them. I just test another VPN company, which you can try to setup and see if you can ping them. They are free. http://www.afreevpn.com/
Here is my result, I can’t ping them.
[admin@MikroTik] /ip firewall nat>> /ping 10.55.0.1
10.55.0.1 timeout
10.55.0.1 timeout
10.55.0.1 timeout
10.55.0.1 timeout
10.55.0.1 timeout
So, if you can help me to test on http://www.afreevpn.com/ and see if you can ping them, that would be great. If you manage to ping them, that means something wrong with the PPTP VPN client on x86 version, and I can based on your testing and my testing and raise a ticket to the developer. Thanks.
I’m posting this from a RB433 using afreevpn.com
It took a routing mark in “/ip firewall mangle” and a new default gateway using that routing mark, but it seems to be working fine. I checked with whatsmyip.com and it shows the afreevpn.com’s public ip.
Just a route rule with routing mark and /ip firewall mangle to mark the packet?
So, you don’t even need masquerade rule?
And you can ping the VPN IP just fine?
My bad. It did take a masquerade also. Everything is working fine. I am on a different computer now, but the other computer is up and running using the new VPN route.
edit: My localnet is 192.168.3.0/24. After I got the VPN running using the user and password from the afreevpn site using testvpn as the name, I entered this:
/ip firewall mangle
add chain=prerouting action=mark-routing new-routing-mark=testvpn src-address=192.168.3.0/24
add dst-address=0.0.0.0/0 gateway=testvpn routing-mark=testvpn
I can conclude something wrong with x86 version, I am gonna raise a ticket. I have the following , baiscally try to mimic your working setup
/ip firewall mangle
add chain=prerouting action=mark-routing new-routing-mark=testvpn src-address=10.0.1.0/24
I can’t even ping the VPN IP address, which in my case is 10.55.0.1.
Mine shows a different dynamic ip assigned to the testvpn interface (10.55.0.54/32) with the same network ip as yours. You will have a routing problem with that setting. Yours has 10.0.1.1 as an address on testvpn. That looks like a routing conflict with one of your localnet interfaces (ether2). ??
I wonder where do I change the testvpn IP? It automatically assign to 10.0.1.1?
Mine was assigned by the VPN server (afreevpn.com). Yours should be also. Maybe that is the problem you are having?
