Please Help with home/office network
Hello everyone, this will be my first post on this forum and hope you can assist me.
I’m not particularly good with network setup, consider myself a beginner at best! But I think its exiting and fun!
I have taken an assignment to make a office/guest network for my mom with two RB962UIGS-5HACT2HNT on Saturday.
both office and guest should have access to internet, but should not be able to communicate with each other.
office iprange: 192.168.10.1/24
guest iprange: 192.168.20.1/24
The first router in first floor.
eth 1 connected to the internet
will distribute office network over 5Ghz only.
will distribute guest network over 5Ghz (virtual wifi), and eth2,3,4
eth 5 will connect to the second router.
Second router in second floor (office )
eth 1 is connected to router 1
will distribute office network over 5Ghz eth2,3,4.
will distrobute guest network on 5Ghz (virtual wifi), and eth5.
I will attach a drawing of the setup:
https://ibb.co/g8HWez
I have been working on this all day, but I’m stuck!
I will post my code below for both routers even tough they are not complete, but I hope someone can make something better than me, and explain whats wrong with my approach so far.
I tried to make separate bridges for the networks with DHCP, and use VLAN between the routers.
My main problem seems to be on router nr.2 i’m not able to get IP address either for guest or office on the lan ports.
I have not yet tested wifi on this router.
Also I don’t understand everything in my configuration, just read a lot of examples I could find, and tried a learn by doing/fake it to you make it approach xD!
I know I will need to upgrade router 1, and I will need a good firewall.
I have not have the joy of playing around with the firewall yet, so if someone have a god setup they would like to share for this application that would also make me happy =D
Would gladly read more myself to figure it out, but time is unfortunately running out for me =S
router1
# sep/20/2018 23:06:08 by RouterOS 6.40.4
# software id = IVLV-8RKI
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = 8A7A08D1F9F5
add name="Guest bridge"
add name="Office bridge"
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment=LAN
set [ find default-name=ether3 ] comment=LAN
set [ find default-name=ether4 ] comment=LAN
set [ find default-name=ether5 ] comment="To Router 2"
set [ find default-name=sfp1 ] disabled=yes
/interface vlan
add interface=ether5 name=vlan10-office vlan-id=10
add interface=ether5 name=vlan20-guest vlan-id=20
add name=WAN
add name=Guest
add name=Office
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    management-protection=allowed mode=dynamic-keys name="office securety" \
    supplicant-identity="" wpa-pre-shared-key=Test1972 \
    wpa2-pre-shared-key=Test1972
    management-protection=allowed mode=dynamic-keys name="Guest security" \
    supplicant-identity="" wpa-pre-shared-key=Test1972 wpa2-pre-shared-key=\
    Test1972
/interface wireless
set [ find default-name=wlan1 ] disabled=no mode=ap-bridge radio-name=\
    AC-Guest security-profile="Guest security" ssid=AC-Guest \
    wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40mhz-Ce \
    disabled=no mode=ap-bridge radio-name=AC-office security-profile=\
    "office securety" ssid=AC-office wireless-protocol=802.11
add keepalive-frames=disabled mac-address=CE:2D:E0:95:08:9C master-interface=\
    wlan2 multicast-buffering=disabled name=wlan3 security-profile=\
    "Guest security" ssid=AC-Guest wds-cost-range=0 wds-default-cost=0 \
    wps-mode=disabled
add name=office_pool ranges=192.168.10.10-192.168.10.200
add name=Guest_pool1 ranges=192.168.20.10-192.168.20.254
add address-pool=office_pool disabled=no interface="Office bridge" name=\
    office-dhcp
add address-pool=Guest_pool1 disabled=no interface="Guest bridge" name=\
    guest-dhcp
add bridge="Office bridge" interface=vlan10-office
add bridge="Guest bridge" interface=vlan20-guest
add bridge="Office bridge" interface=wlan2
add bridge="Guest bridge" interface=wlan3
add bridge="Guest bridge" interface=ether2
add bridge="Guest bridge" interface=ether4
add bridge="Guest bridge" interface=wlan1
add bridge="Guest bridge" interface=ether3
add interface=ether1 list=WAN
add interface="Guest bridge" list=Guest
add interface="Office bridge" list=Office
add address=192.168.10.1/24 interface="Office bridge" network=192.168.10.0
add address=192.168.20.1/24 interface="Guest bridge" network=192.168.20.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.10.0/24 gateway=192.168.10.1
add address=192.168.20.0/24 gateway=192.168.20.1
add action=drop chain=forward dst-address=192.168.20.0/24 src-address=\
    192.168.10.0/24
add action=drop chain=forward dst-address=192.168.10.0/24 src-address=\
    192.168.20.0/24
add action=masquerade chain=srcnat comment="Internett for Guest" \
    out-interface-list=WAN src-address=192.168.20.0/24
add action=masquerade chain=srcnat comment="Internett for Office" \
    out-interface-list=WAN src-address=192.168.10.0/24
/system clock
set time-zone-name=Europe/Oslo
/system identity
set name="Router 1 - Livingroom"
router 2
# sep/20/2018 23:06:25 by RouterOS 6.43.2
# software id = R3MW-T7IK
# serial number = 8A7A0817663D
add fast-forward=no name="Guest Bridge"
add fast-forward=no name="Office Bridge"
set [ find default-name=ether5 ] poe-out=off
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
set [ find default-name=wlan2 ] ssid=MikroTik
/interface vlan
add interface=ether1 name=vlan10-office vlan-id=10
add interface=ether1 name=vlan20-guest vlan-id=20
/ip hotspot profile
add bridge="Office Bridge" interface=vlan10-office
add bridge="Office Bridge" interface=ether2
add bridge="Guest Bridge" interface=ether5
add bridge="Guest Bridge" interface=vlan20-guest
add bridge="Office Bridge" interface=ether3
add bridge="Office Bridge" interface=ether4
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface="Guest Bridge"
add dhcp-options=hostname,clientid disabled=no interface="Office Bridge"
add action=masquerade chain=srcnat disabled=yes dst-address=192.168.20.1 \
    out-interface="Guest Bridge" src-address=192.168.20.0/24
/system clock
/system identity
set name="Router 2 - Office"
/system routerboard settings
set silent-boot=no
I don’t know whether it’s good news or not, but nothing looks clearly broken (or I’m getting blind). Not counting your firewall, I hope you don’t have public address, because you’d be just waiting to get hacked.
Do you have direct cable between the routers or is there any switch that could possibly eat vlan packets? Create some traffic in office and guest LANs on router1 (e.g. keep running ping for some unassigned 192.168.10/20.x address, that will produce arp requests). Then use Tools->Torch on router2’s ether1 and you should see some incoming tagged traffic.
Damn, that was bad news… or at least I think xD
The two routers where connected to my home network, so I was behind a firewall.
Will implement rules before I connect it to get a public IP.
I will try this when I get home again, at work now! Thank you taking time to help =D
extra info:
There is a cable going directly from router1,eth5 to router2,eth1.
I’m running DHCP clients on the bridges on router 2 got an IP address, but I was unable to get a IP on devises connected to eth ports that where connected to the same bridges.
If I remember correct, ROS 6.40 still has that master port configuration. Which means port ether5 is part of switch group and nothing you set on ether5 (including VLANs) doesn’t really work.
My suggestion: upgrade router1 to 6.43.2 and re-apply your current setup. Probability that it all starts to behave is much higher than 0%.
Thank you for that tip!
I will try this tonight =D
