Larsa
June 21, 2025, 7:21pm
1
Looks like there’s a clever extension to the solved plugin that shows related threads right after the solved post.
Check out this thread as an example: https://community.home-assistant.io/t/configured-my-esphome-with-mcp2515-can-bus-for-stiebel-eltron-heating-pump/366053 .
I don’t think that’s something related to the “Solved” plug-in. It’s a feature already available on this instance of Discourse, as you can see in this topic
RouterOS version 7.19 have been released in the “v7 stable” channel!
Before an upgrade:
Remember to make backup/export files before an upgrade and save them on another storage device;
Make sure the device will not lose power during upgrade process;
Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 7.19.2 (2025-Jun-20 10:55):
*) bfd - fixed socket leak;
*) bgp - fixed withdraw when input.accept-nlri is non-existent;
*) btest - properly close unsuc…
Larsa
June 22, 2025, 10:57am
4
Yeah, I noticed that too when I checked out a few more threads.
