I.e. TOR equipment.
You normally have a hot and a cold isle - and, funny enough, because you do not want to mix air, running cables from back to front is not that easy.
It is standard to have switches then mounted in a reverse - patch cables to the back, power supplies to the front. Equipment that may be used in a data center is often also offered in a reverse configuration - basically the airflow going back to front, so cold air is polled in from the back.
And yes, unless you start getting suppliers to provide servers that have the network cards in front (which will not happen) you basically need to run rack internal patching to servers in the back - without creating an air loop.
Cisco and a lot of manufacturers provide switches in reverse configuration as an option - please do the same basically for everything that is enterprise level. 48port gigabit, multiple 25g ports → that stuff is also used in TOR configurations and right now those are problematic, pulling in hot air and emitting it into the cold aisle.
An optimal solution would be configurable - software setting for the case level switches, alternate power supplies or a small switch on the side for power supplies.
For example, Catalyst 4500-X can have two types of fan: Front2Back or Back2Front, this change the airflow,
but at the same time the device (NOT THE FANS) can be mount on any direction, with ports on the back or on the front.
(the F2B fans and B2F fans are two different artiles and can’t be inverted the direction of the flow on software)
I mean, sure, I get the appeal of -F and -R SKUs, but that product diversification costs money, which many of Mikrotik’s customers can’t afford.
Thus, I really don’t see it happening on any product that’s not already using hotswap fans, and even then possibly only via buying an additional -R fan kit.
Because rotating the fans doesn’t simply change direction of air flow inside device, air flow shape can change very much and the result can be inadequate cooling. So -F and -R SKU often differ much more than just regarding fan direction.
It is also not only about the case - it is also about the power supplies. They have their own fans and I generally do not like opening power supplies - at least you would need 2 sets of power supplies or a switch.
And seriously “money they cannot afford”? ARE YOU JOKING? You get a high-end switch for a fraction of the next competitor - and I am not talking of the small stuff here. I talk of the new high-end stuff with 100G links. That is not a 25$ system - they go for 1000 USD or way higher.Plus the network cards and cabling are not cheap either - 10G is run the mill these days, 25G and 100G cards and cables are not.
You also could do a fan direction change by opening and swapping - IF THAT IS CERTIFIED (i.e., if it is in the manual, like adding a M.2 ssd) and thus does (a) not void the warranty and (b) is supposed in that it is documented that it will not overheat part of the system. I would for one be ok with turning the fans (btw., also on the power supplies), but I would love that to be a documented procedure. Like inserting an M.2 - no problem here. It just must be tested.
To address airflow and cable management concerns in data center TOR configurations, reputable network equipment manufacturers offer switches with reverse airflow to pull cool air from the back of the rack and exhaust hot air from the front. Cable management tools like cable lacing bars, trays, and managers can help organize cables and prevent air loops. It’s also important to keep cables short to minimize obstruction of airflow. For power supplies, a configurable solution with alternate power supplies or a small switch on the side can be helpful.
If you don’t like it, don’t buy it.
I’m pretty sure if they had seen added value in it, they would already have adjusted their designs for it. They’re not stupid.
People don’t always control the rack things go into. And they do sell some accessories already. Plus an “enterprise fan” sounds like a high margin item for Mikrotik, that puts them one step closer someone’s definition of enterprise.
Not entirely crazy idea here. Now drilling some holes seems like a quicker solution.
