plzzzzzz need help
hi
i have compact flash (Level 6) with router OS 2.9.44 when i upgrade my system to 3rc13
i have problem with
  1. Unstable signal strength
  2. regular packet loss.
plz i need help to solve this problem.
only one solution i think i have to degrade the OS…? :frowning:
thanx in advance
james
I recommend exporting your settings to a file.
Then Reset the configuration.
Once config has been reset, reconfigure the ros to what you need configured.
Upgrades are not always well behaved.
If you still require a downgrade, then I would recommend a netinstall of the lower version.
indeed, there might be some problems when upgrade from 2.0 to 3.0, so try what tgrand said.
