Just to clarify:
There’s no single “POE standard”; right now POE can be “Active” (af/at) which in addition to sending power by the wires, requires the device to be powered to have specific active circuitry to support it.
This is what most SOHO PoE switches provide, to power most VoIP phones, IP Cameras, which are usually also af/at.
“Passive POE”, refers to just sending the power by the wires, no active circuitry involved. This is what Mikrotik and most WISP segment POE switches provide, targeted to APs, Routers, some IP cameras, etc.
Just noticed wAP, supports both Passive POE, and in addition, Active POE (af/at), with the requirement of using unshielded cable.
I guess this “unshielded” refers to the requirement of not using “armored” or shielded RJ-45s in contact with the cable shield (used to protect from environment interferences) or drain wire (this is used for outdoor installations in order to discharge ESD) so maybe by using non-armored RJ-45s with the shielded cables will do; will research about this approach.
In any case, even if this wasn’t possible, you are going to deal with Active and Passive POE devices, so the more flexible approach is having both an Active (af/at) switch to power your af/at devices (IP Cameras, VoIP phones, other devices) and in addition a Passive POE switch (or POE Injector Patch pannel, like http://www.i4wifi.eu/EU-230V-powering-1/Gigabit-12-port-pasiv-POE-injector-panel-shielded.html) at your network rack, so that you can power both kind of devices and maintain a tidy and neat rack closet.
Active-Passive POE converters are very rare, and usually not worth the cost; also defeat the purpose of neatness at the rack.
Mikrotik devices supporting af/at (a handful models AFAIK) also support passive POE with no shielded cable restrictions, so you can just use Passive POE with all Mikrotik devices.
