Poe with CRS112-8P-4S-IN
Hello!
Simple question, not sure if i am doing in right.
I have above mentioned switch.
I want to poe ccr1009 pc sff+, hap ac x2, cap ac, and poe camera x2.
Is it possible with shipped adapter or i need to buy stronger?
Thx for your answers…
Anyone?
I was searching a little bit…
1amper per port…at 28v…that is 28w per port max…
Ccr is using 33w…hap ac…13w…cap 10w…
So…if i have adapter 28v et 2.8amper…that is around 78w what adapter can produce…
  • 10w for crs…that is around 68w left…
    So i can power 2xhap ac,cap ac, and 2x camera…but ccr is too much?
Use 48V for CCR and you did not get problems
Correct me if i am wrong…what you mean is to plug in crs both 28v and 48v adapters?
right and select 48V for CCR
33W @ 48V = 0,69A no problem for one port
