I’m setting up a 5gh network with rb133c units and several AP’s in a densely populated urbanisation.
I would like to know how the polling (Wireless interface\Nstreme ) is actually working?
Sometimes I have issue connecting clients that are very close to other clients working from the same AP.
Special if they are almost behind another.
I have ‘polling’ enabled (NOT “Nstreme”) on both the clients as the AP’s.
Range of all Clients are 600 mtrs max. and I think I will keep it down to 40 clients each AP.
Up to now I am setting clients power output such that the AP recieves all connected clients within a range of -50 to -60dbm.
To overcome more problems the more clients enlist I want to know how this polling actually works and with that knowledge can create workarounds if needed.
Well, polling is standard enabled, while Nstreame is standard disabled.
Also, nstreame is a way to improbe data througput on wireless links with heavy traffic.
Polling should only be a AP’s tool to tacke the ´Hidden node´ problem of wireless 802.11 networks. I don´t see why is should be combined with nstream.
But then again, I don´t know. Polling could be a great tool to avoid collisions between transmitting clients of the AP if they can’t see each other (´hidden nodes´).
but yes, I do want an explicit answer on the question; If ´polling is enabled´ while nstream is not, is polling then working? Or not?
Well, in 802.11 polling is to do QoS.
It send the frames in allways in a specific time, no one in 0.1 nano, the other 0.3 before another in 0.2… it´s allways like 0.2, 0.2, 0.2… i don´t know if it´s in frequency or the packges but it´s something like this…
Polling doesn’t work without nstreme.
It is enabled by default for convenience.
It really should have been grayed while nstreme was disabled but to each his own.
