Port-base VLAN between Mikrotik and Cisco
Hello Everyone , I’m new in MikroTik. How to configure Port-base VLAN in Mikrotik with Cisco SG 350 and SRW224G4
Background :
1. MikroTik RB750G 2. Cisco SG 350 L3 SW and 3. Linksys SRW224G4 L2 SW
Need Help:
  1. Linksys SRW224G4 (L2): Twenty four (24) different VLANs on this SW
  2. CISCO SG 350 (L3): Inter-Vlan Routing Here
    e.g- VLAN 02- 162.16.2.0/30; VLAN 03- 162.16.3.0/30…VLAN 24- 162.16.24.0/30 (Different Subnet)
  3. VLAN 99 For MGMT- IP 192.168.99.0/28
Now Cisco Part is Ok but Problem is to configure Mikrotik Router
----Router on a stick betwn SG350 and MT with port G26 to MT port Eth-5 (G26 is trunk Port)
What is the best way to do this without misconfiguration and MT port Eth-5 will be the trunk or sub-interface
Plz Help It’s Urgent
There’s a very good tutorial on VLANs in ROS. You did not explain your use case in detail so it’s hard to tell which case explained in the tutorial would fit your needs the best …
Thank You Sir for your Reply…
-Mainly i want to connect Cisco SG350 L3 SW to Mikrotik Router with Trunk Port /Router -on-Stick
  • In Lan side Configuration is ok and inter-Vlan Routing is ok in L3 Switch
    -If you think about the Cisco L3 SW here G26 port is a Trunk - port and G26 port connect to Mikrotik router port 5
    Now need a best way to configure Mikrotik router
