Port based filtering of connections in WinBox
Hi
I’m trying to filter the list of connections under Ip/Firewall/Connections in WinBox based on port(s). Unfortunately I’m unable to figure out how to specify the port and always get an “error” => red marking.
Any idea how to do it?
Thx
I found you only type in the port number, 443 in this case, not the IP or the slash.
It is a little confusing with the “/” in “Src. Address/Port”, makes you think you need to do that in formatting, I just read it as “Src. Address Port” in my head.
If you do want to filter to Source IP in addition, then add another row “+” and select “Src. Address” and type the IP, you will then just see connections for that port from that IP.
Thx!
Very confusing ponctuation.
Without the slash would be better.
