Port Blocking
I have issued this command to my router in hoped to block the default Gnutella ports to prevent filesharing on this network.
add chain=forward in-interface=client out-interface=client src-address=0.0.0.0 dst-address=0.0.0.0 protocol=udp src-port=6346-6350
dst-port=6346-6350 packet-mark=“” action=drop comment=“”
Is the correct command to block incoming and outgoing traffic through the router on ports 6346-6350?
Thanks in advance!
No, I think the right way would be something like this one. Correct me if I’m wrong.
/ ip firewall filter
add chain=forward p2p=gnutella action=drop comment="" disabled=no
hey Borage ur idea is correct
and if you know the ports of gnutela … you can block it manually but try not to specify the interfaces …
just add protcool: tcp dst-port: xxxx action drop in the forwward chain
