Port Disabled
I have ran into a problem with my Mikrotik. I had the same problem a few months back and it just cured its self. But it has happened again on a different unit and won’t fix magically. The wireless card is showing that it is not running in the interface column and in the bridge it shows “disabled port” on the role. Any help would be great.
Well if nothing is associated to the wireless card (when AP) or the card is not associated to an AP (station) then the interface is “not running”. It will flip to running when the association completes (or at least one client associates). You can set Disable-Running-Check=yes to force the interface to always “run”.
