Port forward problem
Hi!
i’m not able to forward port 433 from wan to 192.168.1.90
please advice (any other advice is also greatly appreciated)
thank you in advance
# apr/16/2020 20:01:30 by RouterOS 6.47beta49
# software id = R192-XR03
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = 67370579848F
add admin-mac=5C:6A:80:4F:17:58 auto-mac=no fast-forward=no name=IPTV-Bridge
add admin-mac=E4:8D:8C:49:2B:64 auto-mac=no comment=defconf igmp-snooping=yes \
    name=bridge
set [ find default-name=ether1 ] advertise=10M-full,100M-full,1000M-full \
    rx-flow-control=auto tx-flow-control=auto
set [ find default-name=ether2 ] advertise=10M-full,100M-full,1000M-full \
    comment=Stua rx-flow-control=auto tx-flow-control=auto
set [ find default-name=ether3 ] advertise=10M-full,100M-full,1000M-full \
    comment=Loftet rx-flow-control=auto tx-flow-control=auto
set [ find default-name=ether4 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether5 ] advertise=10M-full,100M-full,1000M-full \
    comment=Freenas rx-flow-control=auto tx-flow-control=auto
set [ find default-name=sfp1 ] advertise=10M-full,100M-full,1000M-full \
    mac-address=5C:6A:80:4F:17:58
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=taugata24 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=taugata24_5g wireless-protocol=\
    802.11
/interface vlan
add comment=Phone interface=sfp1 name=vlan100 vlan-id=100
add comment=IPTV interface=sfp1 name=vlan101 vlan-id=101
add comment=Internet interface=sfp1 name=vlan102 vlan-id=102
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.1.100-192.168.1.254
add address-pool=dhcp disabled=no interface=bridge name=dhcp1
add bridge=bridge comment=defconf disabled=yes interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=ether1
add bridge=IPTV-Bridge interface=vlan101
/interface bridge settings
set use-ip-firewall=yes
/ip settings
set accept-source-route=yes
add interface=vlan102 list=WAN
add address=192.168.1.1/24 comment=defconf interface=ether1 network=\
    192.168.1.0
/ip dhcp-client
add comment=Internett disabled=no interface=vlan102
add add-default-route=no comment=IPTV dhcp-options=clientid,hostname \
    disabled=no interface=IPTV-Bridge
add disabled=no interface=sfp1
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
/ip firewall address-list
add address=192.168.1.0/24 list=support
add action=accept chain=forward connection-nat-state=dstnat connection-state=\
    established,related in-interface=vlan102 protocol=tcp
add action=accept chain=input connection-state=established,related
add action=accept chain=input connection-state=new
add action=accept chain=input protocol=udp
add action=accept chain=input protocol=igmp
add action=accept chain=forward protocol=udp
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes \
    protocol=icmp
    established,related,untracked disabled=yes
add action=drop chain=input disabled=yes dst-port=53 in-interface=vlan102 \
    protocol=udp
    disabled=yes ipsec-policy=in,ipsec
    invalid disabled=yes
    "defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
    dst-address=127.0.0.1
    disabled=yes in-interface-list=!LAN
    disabled=yes ipsec-policy=out,ipsec
    connection-state=invalid disabled=yes
    connection-state=new disabled=yes in-interface=vlan102
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address=172.21.0.0/16 \
    new-routing-mark=IPTV-Mark passthrough=yes src-address=0.0.0.0/0
add action=masquerade chain=srcnat out-interface=vlan102 to-addresses=0.0.0.0
add action=masquerade chain=srcnat out-interface=IPTV-Bridge
add action=dst-nat chain=dstnat dst-port=443 in-interface=vlan102 protocol=\
    tcp to-addresses=192.168.1.90 to-ports=443
add disabled=yes distance=1 gateway=10.164.44.1 routing-mark=IPTV-Mark
/ip route rule
add routing-mark=IPTV-Mark table=IPTV-Mark
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=vlan102 type=external
add interface=sfp1 type=external
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/routing igmp-proxy
set quick-leave=yes
/routing igmp-proxy interface
add alternative-subnets=0.0.0.0/0 interface=IPTV-Bridge upstream=yes
/system clock
set time-zone-name=Europe/Oslo
/tool graphing interface
/tool mac-server
/tool mac-server mac-winbox
I saw that you wrote port 433 in the forum but the code is for port 443, I will asume that you want to nat the https port to this IP address.
The code seems to be all right
I never have used the “to_addresses” with 0.0.0.0 in the masquerade rule, I dont know if this works.
Did you check that the 192.168.1.90 address is accessible from the router and this is listening on port 443?
If this is a Windows machine, you can type the following in command line to check
netstat -noa | findstr "443"
Otherwise you can check in other PC with Windows if this device is listening on port 443 with the following command:
telnet 192.168.1.90 443
Or just open a browser and write the ip address on it
If you cannot connect from another computer, then the issue is not the Mikrotik.
If you can connect from inside, maybe the problem is that 0.0.0.0, not sure what does it do.
Regards,
Damián
