Both of them should result in a functioning setup.
But does setting the dst-address (public IP) have any benefits here?
If you have two WAN/IPs it will make a difference because one will only work on one IP while the other will work on all public IPs.
But is there any other security concern of just setting the in-interface-list?
Thanks a lot in advance!
I read through the wiki but did not find any answers to those questions yet.
It doesn’t matter if it’s just a WAN or not, better restrict the rule to the expected IP.
Otherwise any spoofed IP coming from the WAN can pass the rule…
I’ll spare you the usual comments about opening unsafe services (ftp) to the outside…
Through other rules it is better that you also limit the simultaneous connections to the internal server already from here
(search in the documentation and in the forum how to do it)
otherwise a brute force attack or a DDoS can create you problems…
Better if you create one address list of allowed outside addresses and use on the rule the list as allowed src-address-list.
Thanks for your answer!
I don't know the IP of the clients as those are dynamic.
So I can't really restrict it to the expected IP if I understand it correct?
Use of dst-address=WANIP makes sense for fixed/static WANIPs
Use of in-interface-list=WAN or in-interface=WAN1 etc, makes sense for dynamic WANIPs
In the case of hairpin nat, where the admin requires users to reach the server and the users are in the same subnet as the server then 2) the dynamic case wont work and you need to find an alternative approach. ( users are not coming in from the WAN so the rule is no longer relevant ) The most common is dst-address-list=DYNWAN ( any name will do ) where
firewall address list
add address=myipcloudaddress list=DYNWAN
Security thoughts,
Running servers on the LAN invites interest and its best to, on the dst-nat rules, includes source addresses → list of who is allowed to access your servers…
THis is doable considering you need users IP addresses, so they either have fixed WANIPs and if they have dynamic WANIPs, they can get free domain names on the net to associate their WANIP and you can use the domain name in firewall address lists…
Finally, there is something called Zero Trust Tunnel which is a way of completely avoiding the use of your WANIP for port forwarding to servers on the LAN. Sadly, Mikrotik had decided not to make this functionality available in ROS proper or in a separate package, it is something a limited amount of MT devices can do, (those can can host dockers/containers), with a lot of added complexity and of course the counter-intuitive (in this case ) security risk containers bring.
Variant 1) has additional advantage: makes configuring hairpin NAT a home run. So yes, if WAN IP is truly static (i.e. it’s configured under /ip address), then 1) is the way to go.
Performance wise, I expect both variants to be equally resource demanding.
If you have a dynamic public ip-address there’s a trick to solve this problem.
You can add a address-list and specify your domain/dynamic dns here and can match agains this address list. The address list looks-up your correct public IP and you can match agains this.
