Hey all. Can some please help me to setup simple port forwarding which i really don’t get. ![]()
Came from D-LINK where it was super simple out-of-box UI and am a little frustrated with Mikrotik firewall settings.
All i need is to do a port forwarding the following way:
WAN(10.10.10.10) — Mikrotik ---- server(192.168.88.10:8123)
So i could access server by going to 10.10.10.10:8123 both locally and externally.
As well as SSH to the server by using 10.10.10.10:733
WAN(10.10.10.10) — Mikrotik ---- server(192.168.88.10:733)
With what i currently have i was able to connect to the server 10.10.10.10:8123, but only externally. It doesn’t work when i m trying that internally over wlan.
[admin@MikroTik] > export hide-sensitive
# feb/23/2020 17:00:39 by RouterOS 6.46.3
# software id = 63WL-9G9C
# model = 2011UiAS-2HnD
# serial number = 467304B1DBAF
add admin-mac=4C:5E:0C:43:D6:3E auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=sweden disabled=no distance=indoors installation=indoor mode=ap-bridge ssid="The Apartment" wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.11-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat comment="Raspberry Pi" dst-port=8123 in-interface=ether1 protocol=tcp to-addresses=192.168.88.10 to-ports=8123
/system clock
set time-zone-name=Europe/Stockholm
/system routerboard settings
set auto-upgrade=yes cpu-frequency=700MHz silent-boot=yes
/tool mac-server
/tool mac-server mac-winbox
